Hi dear,
I’m getting crazy, I can’t perform almost any action after a fresh install (+ config upload) in GoldEye, almost every command get me back:
RuntimeError: aclmode: failed to get property: <UNKNOWN>.
I think that i broke something ith ACLs, please help me!
Here the full log of the error is this:
Error Name: EINVAL
Error Code: 22
Reason: aclmode: failed to get property: <UNKNOWN>.
Error Class: RuntimeError
Trace: Traceback (most recent call last):
File "/usr/lib/python3/dist-packages/middlewared/api/base/server/ws_handler/rpc.py", line 360, in process_method_call
result = await method.call(app, id_, params)
File "/usr/lib/python3/dist-packages/middlewared/api/base/server/method.py", line 57, in call
result = await self.middleware.call_with_audit(self.name, self.serviceobj, methodobj, params, app,
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 954, in call_with_audit
result = await self._call(method, serviceobj, methodobj, params, app=app,
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 771, in _call
File "/usr/lib/python3/dist-packages/middlewared/service/crud_service.py", line 196, in delete
return await self.middleware._call(
File "/usr/lib/python3/dist-packages/middlewared/service/crud_service.py", line 214, in nf
rv = await func(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/api/base/decorator.py", line 108, in wrapped
result = await func(*args)
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/dataset.py", line 826, in do_delete
dataset = await self.get_instance(id_)
File "/usr/lib/python3/dist-packages/middlewared/service/crud_service.py", line 236, in get_instance
instance = await self.middleware.call(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1043, in call
return await self._call(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 782, in _call
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 665, in run_in_executor
File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run
File "/usr/lib/python3/dist-packages/middlewared/api/base/decorator.py", line 116, in wrapped
result = func(*args)
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/dataset.py", line 161, in query
return generic_query(
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/dataset_query_utils.py", line 1080, in generic_query
rsrc_iterator(callback=generic_query_callback, state=state)
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/dataset_query_utils.py", line 997, in generic_query_callback
hdl.iter_filesystems(callback=generic_query_callback, state=state)
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/dataset_query_utils.py", line 920, in generic_query_callback
info = build_info(hdl, state)
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/dataset_query_utils.py", line 727, in build_info
tmp = hdl.asdict(
I’m a SCALE newbie coming from CORE that I’ve used more than 10 years.
