Add iotop to system
Hi, please add iotop.
I wanted to figure out which process performs read/write operations on the pool.
On the Internet they write that this can be done using iotop - but this utility is not on the system.
I stopped all applications but it did not help.
As far as I understand, I am not the only one with this problem - Exos power management on SCALE
System Dataset Pool is on the boot-pool.
TrueNAS-SCALE-24.04.2.3
in the end iotop didn’t help find who was accessing the files, but fatrace did. I downloaded fatrace, put it on the zfs pool and launched it)
maybe command htop helps
