Adding ipv6 alias: "Interface xxxx is currently in use"
Trying to add ipv6 address to LACP bond and get this error:
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 198, in call_method
    result = await self.middleware.call_with_audit(message['method'], serviceobj, methodobj, params, self)
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1466, in call_with_audit
    result = await self._call(method, serviceobj, methodobj, params, app=app,
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1417, in _call
  File "/usr/lib/python3/dist-packages/middlewared/service/crud_service.py", line 189, in update
    return await self.middleware._call(
  File "/usr/lib/python3/dist-packages/middlewared/service/crud_service.py", line 210, in nf
    rv = await func(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 47, in nf
    res = await f(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 187, in nf
  File "/usr/lib/python3/dist-packages/middlewared/plugins/network.py", line 1257, in do_update
    verrors.check()
  File "/usr/lib/python3/dist-packages/middlewared/service_exception.py", line 70, in check
    raise self
middlewared.service_exception.ValidationErrors: [EINVAL] interface_update.lag_ports.0: Interface ens2d1 is currently in use
