this is the app config in web ui:
Edit memos
Application name
Application Name
memos
Container Images
Docker Image
help_outline
Image repository
help_outline
Image Tag
help_outline
stable
Image Pull Policy
help_outline
Only pull image if not present on host
Section Help
Image to be used for container
Container Entrypoint
Container CMD
No items have been added yet.
Container Args
Section Help
Configuration of the executable that will be run when the container is started
Container Environment Variables
Environment Variable Name
help_outline
MEMOS_ADDR
Environment Variable Value
help_outline
10 0 0 33
help_outline
MEMOS_PORT
help_outline
5231
Section Help
Set the environment that will be visible to the container
Networking
Add external Interfaces
Host Interface
help_outline
‘enp4s0’ Interface
IP Address Management
help_outline
IPAM Type
help_outline
Use static IP
Static IP Addresses
Static IP
10 0 0 33
24
Static Routes
DNS Policy
help_outline
Use Default DNS Policy where Pod will inherit the name resolution configuration from the node.
DNS Configuration
help_outline
Nameservers
Nameserver
10 0 0 2
Nameserver
1 1 1 1
Searches
DNS Options
Section Help
Configure networking for container
Port Forwarding
Specify Node ports to forward to workload
Section Help
Configure ports to forward to workload
Storage
Host Path Volumes
Memory Backed Volumes
Volumes
Mount Path
help_outline
/var/opt/memos
Dataset Name
memos
Section Help
Persist and share data that is separate from the lifecycle of the container
Workload Details
Enable TTY
help_outline
Enable STDIN
help_outline
Security Context
Privileged Mode
help_outline
Capabilities
Configure Container User and Group ID
help_outline
Section Help
Configure how workload should be deployed
Scaling/Upgrade Policy
Update Strategy
help_outline
Create new pods and then kill old ones
Section Help
Configure how pods are replaced when configuration is upgraded
Resource Reservation
GPU Configuration
GPU Resource ()
help_outline
Allocate 0 amd.com/gpu GPU
GPU Resource ()
help_outline
Allocate 0 GPU
GPU Resource ()
help_outline
Allocate 0 GPU
Section Help
Specify resources to be allocated to workload
Resource Limits
Enable Pod resource limits
Section Help
Set CPU/memory limits for Kubernetes Pod
Portal Configuration
Enable WebUI Portal
help_outline
Section Help
Configure UI web portalstrong text
