Clean reinstall involving mirrored boot pool
I am running Scale 25.10.2.1 on a mirrored boot pool. Do I have to undo the mirror before I reinstall?
How?
Advise, please
You shouldn’t have to but if you have trouble you use zpool detach to remove one drive from the mirror. I couldn’t find a way to remove using the GUI, inside of a VM.
Thank you very much, @SmallBarky
That was my problem - there is no GUI option to break the mirror.
I will study the zpool man page and make sure I broke something I can’t fix. lol
