After upgrading from dragonfish to electric Eel
IN storage disk you can set the columns to see for example the description, disk type, model
but doesn’t memorize your choice, every time you have to reselect the columns you desire.
Instead dragon Fish was holding your choices infact in both version there is
the button reset to default,
And in dragonfish the columns wide was right to show the description
column wide was greater for description than disk type column and was clear
now instead is like the column has got the same size and description for example is not easy to read
