Concurrent system jobs in Scale?
I have sidegraded from Core to Scale last night. And I need to change some user permissions on folders because of Apps mainly.
Currently, I am changing a folder with 7TB or so data in it, which will take hours/days to complete I see.
In the mean time, when I want to add a dataset (even to another pool), or change a user setting (like adding an SSH key), it just queues them (waiting… it says under Jobs).
Is there a way to have some jobs to run concurrently? I understand you don’t want to mess with child datasets in a dataset that has pending ACL settings. But other actions all seem to be queued while I think you should be able to process them, like even ACL settings on smaller datasets separate from the large one.
Thanks
I found this post
In the mean time, the ACL change has been running for over 2 days, I do see progress in the shell, and expect I need another 2 full days for this dataset alone.
