Defaut nextcloud installation
I tried everything it does not work, normally with the information entered in the installation of NextCloud it should not have a problem, but then I ask myself the question if it does not come from dockers
et when I deactivate the ssl trunas by default and well I have access to the login page but impossible to connect with my login and password
Well I did an installation without activated the certicat ssl trunas by default at the time of the installation of NextCloud and I have been accessing the login page but the password and login does not work so it a problem of Installation which is not valid and operational, really too null it does not work
