[ENOENT] Path not found (TrueNAS 25.10)
Today I updated my TrueNAS to version 25.10.
I also moved a disk set from a TrueNAS 13 to this same storage. I imported the pool and configured NFS to use a dataset from this pool.
At times, the UI gives the error shown below, and other times it works fine. I don’t understand why it sometimes works and sometimes doesn’t. I can’t use the pool via iSCSI—it gives an error that the path does not exist.
Can you help me understand what is happening?
Error Name: ENOENT
Error Code: 2
Reason: [ENOENT] Path not found.
Error Class: CallError
Trace: Traceback (most recent call last):
File “/usr/lib/python3/dist-packages/middlewared/api/base/server/ws_handler/rpc.py”, line 360, in process_method_call
result = await method.call(app, id_, params)
File “/usr/lib/python3/dist-packages/middlewared/api/base/server/method.py”, line 57, in call
result = await self.middleware.call_with_audit(self.name, self.serviceobj, methodobj, params, app,
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 954, in call_with_audit
result = await self._call(method, serviceobj, methodobj, params, app=app,
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 782, in call
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 665, in run_in_executor
File “/usr/lib/python3.11/concurrent/futures/thread.py”, line 58, in run
File “/usr/lib/python3/dist-packages/middlewared/api/base/decorator.py”, line 116, in wrapped
result = func(*args)
File "/usr/lib/python3/dist-packages/middlewared/plugins/filesystem
/acl.py", line 483, in getacl
raise CallError(‘Path not found.’, errno.ENOENT)
middlewared.service_exception.CallError: [ENOENT] Path not found.
zfs get all conexum
NAME PROPERTY VALUE SOURCE
conexum type filesystem -
conexum creation Tue Sep 16 11:31 2025 -
conexum used 1.36T -
conexum available 8.64T -
conexum referenced 139K -
conexum compressratio 1.15x -
conexum mounted yes -
conexum quota 10T local
conexum reservation none default
conexum recordsize 64K local
conexum mountpoint /mnt/conexum default
conexum sharenfs off default
conexum checksum on local
conexum compression lz4 local
conexum atime off local
conexum devices on default
conexum exec on local
conexum setuid on default
conexum readonly off local
conexum zoned off default
conexum snapdir hidden local
conexum aclmode discard local
conexum aclinherit passthrough local
conexum createtxg 1 -
conexum canmount on default
conexum xattr on default
conexum copies 1 local
conexum version 5 -
conexum utf8only off -
conexum normalization none -
conexum casesensitivity sensitive -
conexum vscan off default
conexum nbmand off default
conexum sharesmb off default
conexum refquota none default
conexum refreservation none default
conexum guid 10200547032831979845 -
conexum primarycache all default
conexum secondarycache all default
conexum usedbysnapshots 0B -
conexum usedbydataset 139K -
conexum usedbychildren 1.36T -
conexum usedbyrefreservation 0B -
conexum logbias latency default
conexum objsetid 54 -
conexum dedup off local
conexum mlslabel none default
conexum sync disabled local
conexum dnodesize legacy default
conexum refcompressratio 1.00x -
conexum written 139K -
conexum logicalused 1.47T -
conexum logicalreferenced 46.5K -
conexum volmode default default
conexum filesystem_limit none default
conexum snapshot_limit none default
conexum filesystem_count none default
conexum snapshot_count none default
conexum snapdev hidden local
conexum acltype posix local
conexum context none default
conexum fscontext none default
conexum defcontext none default
conexum rootcontext none default
conexum relatime on default
conexum redundant_metadata all default
conexum overlay on default
conexum encryption off default
conexum keylocation none default
conexum keyformat none default
conexum pbkdf2iters 0 default
conexum special_small_blocks 0 local
conexum prefetch all default
conexum direct standard default
conexum longname off default
conexum defaultuserquota 0 -
conexum defaultgroupquota 0 -
conexum defaultprojectquota 0 -
conexum defaultuserobjquota 0 -
conexum defaultgroupobjquota 0 -
conexum defaultprojectobjquota 0 -
conexum org.freenas:description local
