Error while passing usb devices
I was passing multiple usb devices and after vm reboot, I got an error “no more usb devices”. Now when i even try to open virtualization tab i’m getting an error “cannot serialize None (type NoneType)”
  File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/supervisor.py", line 38, in domain_health_check
    self._domain.state()
AttributeError: 'NoneType' object has no attribute 'state'
  File "/usr/lib/python3.11/xml/etree/ElementTree.py", line 1041, in _escape_attrib
    if "&" in text:
TypeError: argument of type 'NoneType' is not iterable
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 201, in call_method
    result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self)
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1342, in _call
  File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 44, in nf
    res = await f(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 177, in nf
  File "/usr/lib/python3/dist-packages/middlewared/service/crud_service.py", line 159, in query
    result = await self.middleware.call(
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1399, in call
    return await self._call(
  File "/usr/lib/python3/dist-packages/middlewared/plugins/datastore/read.py", line 169, in query
    result = await self._queryset_serialize(
  File "/usr/lib/python3/dist-packages/middlewared/plugins/datastore/read.py", line 217, in _queryset_serialize
    extend_context_value = await self.middleware.call(extend_context, rows, extra_options)
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1353, in _call
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1251, in run_in_executor
  File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run
  File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vms.py", line 103, in extend_context
    status[row['id']] = self.status_impl(row)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vms.py", line 467, in status_impl
    if self._has_domain(vm['name']):
  File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_supervisor.py", line 22, in _has_domain
    return vm_name in self.vms and self.vms[vm_name].domain
  File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/supervisor.py", line 119, in __getattribute__
    retrieved_item = object.__getattribute__(self, item)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/supervisor.py", line 34, in domain
    return self.domain_health_check()
  File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/supervisor.py", line 40, in domain_health_check
    self.update_domain(update_devices=False)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/supervisor.py", line 66, in update_domain
    self.__define_domain()
  File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/supervisor.py", line 98, in __define_domain
    vm_xml = etree.tostring(self.construct_xml()).decode()
  File "/usr/lib/python3.11/xml/etree/ElementTree.py", line 1098, in tostring
    ElementTree(element).write(stream, encoding,
  File "/usr/lib/python3.11/xml/etree/ElementTree.py", line 743, in write
    serialize(write, self._root, qnames, namespaces,
  File "/usr/lib/python3.11/xml/etree/ElementTree.py", line 906, in _serialize_xml
    _serialize_xml(write, e, qnames, None,
  [Previous line repeated 1 more time]
  File "/usr/lib/python3.11/xml/etree/ElementTree.py", line 899, in _serialize_xml
    v = _escape_attrib(v)
  File "/usr/lib/python3.11/xml/etree/ElementTree.py", line 1064, in _escape_attrib
    _raise_serialization_error(text)
  File "/usr/lib/python3.11/xml/etree/ElementTree.py", line 1018, in _raise_serialization_error
    raise TypeError(
TypeError: cannot serialize None (type NoneType)
TrueNAS-SCALE-23.10.2
