EVEN More efficient one way up sync from TrueNAS to Proton Drive
My original requirements have not changed from the original implementation that I posted here:
https://forums.truenas.com/t/more-efficient-one-way-up-sync-from-truenas-to-proton-drive
but that implementation, which used rclone and while working beautifully and reliably, was eventually killed by Proton nuking rclone reverse engineered way of access. But, kudos to Proton team, they released their own, official CLI and it works much faster and more reliable than rclone.
So, my needs are simple - infrequent secure online access to my personal files that reside on TrueNAS and also use that Proton Drive as pseudo backup of sort. I designed this process to be gentle on API and not to over use/abuse API calls, so it only upload new and changed files, and propagates local deletions to Proton Drive keeping local and online folders and files in sync.
This is only one way - UP - sync of the local files. If anything modified/added/deleted online - it will not be reflected on TrueNAS. Moreover, if an online folder is deleted but local still exist, then changes of/in that local folder (new/changed/deleted files), will log an error - this is by design, I do not "fix"it by auto creating a missing folder, as that would simply mask the underlying problem without me knowing about it - I’d rather see the error and determine what happened. But, if used properly, this should never happen.
So, here is Proton Drive CLI: Using Proton Drive CLI | Proton
Here is how to set this up:
! IMPORTANT
!!! Replace:
YOURPOOL with your Data pool name
YOUHOMEFOLDER with your folder name where all of this will be located
My previous implementation used rclone, which was part of the OS, but Proton Drive CLI is not. So, we need to download it an place it where OS update will not wipe it off. User home is good as any other folder.
create folder:
mkdir proton-drive-cli
cd proton-drive-cli
download the binary:
wget ``https://proton.me/download/drive/cli/0.6.0/linux-x64/proton-drive
make it executable:
chmod +x proton-drive
proton-drive requires parameters to tell it how to authenticate, to simplify we put these parameters into a file, create file:
proton-drive-cli-sync
write to file:
#!/bin/bash
export PROTON_DRIVE_CREDENTIALS_STORE=unsafe_file
export PROTON_DRIVE_CACHE_DIR=“/mnt/Datapool/home/YOUHOMEFOLDER/proton-drive-cli/session”
exec “/mnt/YOURPOOL/home/YOUHOMEFOLDER/proton-drive-cli/proton-drive” “$@”
make it executable:
chmod +x proton-drive-cli-sync
inside “proton-drive-cli” create a new folder “session” for the official Proton drive to save authentication token and session data, this must be created before you try to authenticate
Lock down the directory permissions so only your user can read the token:
chmod 700 /mnt/YOURPOOL/home/YOUHOMEFOLDER/proton-drive-cli/session
from now on, proton-drive-cli-sync can be called in place of proton-drive
To authenticate, run:
./proton-drive-cli-sync auth login
copy the provided url to authenticate in a browser, once logged in, Proton authentication session will get the response automatically and proceed on its own
to test, run:
./proton-drive-cli-sync filesystem list /
response shold be the list of your files
That’s it! The official Proton-Drive is now configured, remembers credentials, and can be called from a script.
My script is below. Works similarly to the previous version.
If it runs the first time, it will enumerate the SOURCE_DIR and upload its content up. If you already have your files up on Proton, no need to re-upload, use --resetstate switch which causes the script to take a snapshot of the SOURCE_DIR, record its state, and ASSUME that all files are already online - skipping the upload.
From now on, instead of the entire file storage synchronization, which could easily take hours or even days for many of us, only new/changed/deleted files and folders will be propagated to Proton Drive.
The script takes EXCLUDE_FILE parameter in form of a text file listing folders to exclude form its operations, but as of now only full paths are supported, no wild cards, which I plan to add later.
To configure this script, modify the variables listed under # — Script Configuration — header
After creating this script, make it executable: chmod +x script_file_name.sh
Finally, you can schedule this under cron jobs. Go System/Advanced Settings/Cron Jobs and create a new job with your desired schedule. Use this for the job command:
/mnt/YOURPOOL/home/YOUHOMEFOLDER/proton_file_tracker/pd_file_sync_script.sh --timeout 12h > /dev/null 2>&1
To be safe, also check “Hide Standard Output”
DONE
SCRIPT (EXCLUSION FILE BELOW THE SCRIPT):
#!/bin/bash
# /mnt/YOURPOOL/home/YOUHOMEFOLDER/proton_file_tracker/pd_file_sync_script.sh
# Version History:
#   v8.0:
#		- Architecture Overhaul: Replaced rclone with official Proton Drive CLI wrapper
#      	- Implemented linear sequential execution (Trash Files -> Trash Folders -> Upload Files)
#		- Added custom retry logic for native CLI commands
#		- Retained pristine SQLite local tracking to minimize API overhead
#   v8.1:
#		- Added explicit pre-creation of new folders via filesystem create-folder to prevent upload path errors.
#		- Corrected remote target path syntax.
#	v8.2:
#		- Added abort logic to resolve uploading to a not existing folder
# --- Script Configuration ---
SOURCE_DIR="/mnt/YOURPOOL/Docs"
DB_DIR="/mnt/YOURPOOL/home/YOUHOMEFOLDER/proton_file_tracker"
LOG_DIR="/mnt/YOURPOOL/Docs/Docs/Computers & Related/Logs"
LOG_FILE="${LOG_DIR}/2026 Home NAS to Proton.log"
EXCLUDE_FILE="${LOG_DIR}/excluded.txt"
# --- Proton Drive CLI Configuration ---
PD_CLI="/mnt/YOURPOOL/home/YOUHOMEFOLDER/proton-drive-cli/proton-drive-cli-sync"
REMOTE_DIR="/my-files/Home-NAS"
# --- Path Sanitization ---
SOURCE_DIR="${SOURCE_DIR%/}/"
REMOTE_DIR="${REMOTE_DIR%/}"
# --- Temporary file definitions ---
DB_FILES="$DB_DIR/file_tracker.db"
CURRENT_FILES="$DB_DIR/current_files.txt"
CHANGED_FILES="$DB_DIR/changed_files.txt"
DELETED_FILES="$DB_DIR/deleted_files.txt"
DB_FOLDERS="$DB_DIR/folder_tracker.db"
CURRENT_FOLDERS="$DB_DIR/current_folders.txt"
NEW_FOLDERS="$DB_DIR/new_folders.txt"
DELETED_FOLDERS="$DB_DIR/deleted_folders.txt"
# --- Script state variables ---
RESET_STATE=0
FIRST_RUN=0
TIMEOUT_DURATION=""
WATCHDOG_PID=""
SYNC_ERROR=0
# --- Function Definitions ---
validate_duration() {
    local duration=$1
    if ! [[ "$duration" =~ ^[0-9]+[smhd]$ ]]; then
        echo "Error: Invalid duration format: '$duration'." >&2
        exit 1
    fi
usage() {
    echo "Usage: $0 [--resetstate] [--timeout DURATION] [--help]"
    echo "Synchronizes $SOURCE_DIR to $REMOTE_DIR using local DB tracking, excluding folders in $EXCLUDE_FILE."
    exit 0
cleanup_and_exit() {
    echo "$(date '+%Y-%m-%d %H:%M:%S') - An error occurred or script was interrupted. Cleaning up..." >> "$LOG_FILE"
    pkill -TERM -P $$ find sqlite3 proton-drive &>/dev/null
    rm -f "$CHANGED_FILES" "$DELETED_FILES" "$CURRENT_FILES" "$DELETED_FOLDERS" "$NEW_FOLDERS" "$CURRENT_FOLDERS"
    rm -f "$DB_DIR/find_error.log" "$DB_DIR/sqlite_error.log"
    exit 1
timeout_exit() {
    echo "$(date '+%Y-%m-%d %H:%M:%S') - Timeout of $TIMEOUT_DURATION exceeded." >> "$LOG_FILE"
    exit 1
write_log() {
    if [ -f "$1" ]; then
        while IFS= read -r line; do
            echo "$(date '+%Y-%m-%d %H:%M:%S') - $line" >> "$LOG_FILE"
        done < "$1"
    else
        echo "$(date '+%Y-%m-%d %H:%M:%S') - $1" >> "$LOG_FILE"
    fi
log_footer() {
    local new_changed_count=$1
    local deleted_count=$2
    local deleted_folder_count=$3
    printf "#%.0s" {1..80} >> "$LOG_FILE"; echo >> "$LOG_FILE"
    write_log "Sync completed successfully"
    write_log "New/changed files: $new_changed_count"
    write_log "Deleted files: $deleted_count"
    write_log "Deleted folders: $deleted_folder_count"
    echo "" >> "$LOG_FILE"
# Wrapper for Proton CLI commands to add retry logic
run_pd_cli_with_retry() {
    local max_attempts=3
    local attempt=1
    local exit_code=0
    local temp_output="$DB_DIR/pd_cli_temp.log"
    while [ "$attempt" -le "$max_attempts" ]; do
        # Execute command and capture its true exit code immediately
        "$@" > "$temp_output" 2>&1
        exit_code=$?
        # Evaluate the captured exit code
        if [ "$exit_code" -eq 0 ]; then
            rm -f "$temp_output"
            return 0
        fi
        write_log "Attempt $attempt failed for command: $*"
        write_log "$temp_output"
        sleep 5
        ((attempt++))
    done
    return $exit_code
# --- Parse Arguments ---
while [[ $# -gt 0 ]]; do
    case "$1" in
        --resetstate) RESET_STATE=1; shift ;;
        --timeout)
            if [[ -n "$2" ]]; then TIMEOUT_DURATION="$2"; validate_duration "$TIMEOUT_DURATION"; shift 2;
            else echo "Error: --timeout requires duration." >&2; exit 1; fi ;;
        --help) usage ;;
        *) echo "Error: Unknown option: $1" >&2; exit 1 ;;
    esac
done
# --- Watchdog ---
MAIN_PID=$$
cleanup_watchdog() {
    if [[ -n "$WATCHDOG_PID" ]] && kill -0 "$WATCHDOG_PID" 2>/dev/null; then
        kill "$WATCHDOG_PID" 2>/dev/null
        wait "$WATCHDOG_PID" 2>/dev/null
    fi
trap cleanup_watchdog EXIT
trap 'cleanup_and_exit' ERR INT
trap 'timeout_exit' TERM
# --- Start ---
mkdir -p "$DB_DIR" "$LOG_DIR"
write_log "Sync operation started"
if [[ -n "$TIMEOUT_DURATION" ]]; then
    ( exec sleep "$TIMEOUT_DURATION"; kill -TERM "$MAIN_PID" ) &
    WATCHDOG_PID=$!
    write_log "Timeout watchdog started: $TIMEOUT_DURATION."
fi
# --- Exclusions ---
FIND_EXCLUDE_ARGS=()
if [ -f "$EXCLUDE_FILE" ]; then
    while IFS= read -r rule; do
        if [[ -z "$rule" || "$rule" =~ ^[[:space:]]*# ]]; then continue; fi
        rule=$(echo "$rule" | tr -d '\r' | xargs)
        [ -z "$rule" ] && continue
        find_path=$(echo "$rule" | sed 's#/\*\*##; s#/$##')
        if [ -n "$find_path" ]; then
            FIND_EXCLUDE_ARGS+=(-path "$SOURCE_DIR$find_path" -prune -o)
        fi
    done < "$EXCLUDE_FILE"
fi
if [[ "$RESET_STATE" -eq 1 ]]; then
    write_log "Resetting state due to --resetstate."
    rm -f "$DB_FILES" "$DB_FOLDERS"
fi
# Check Proton Drive Auth
if [ "$RESET_STATE" -eq 0 ]; then
    if ! "$PD_CLI" filesystem list / >/dev/null 2>&1; then
        write_log "Error: Proton Drive CLI authentication failed. Run the wrapper manually to fix."
        cleanup_and_exit
    fi
fi
# --- Initialize DBs and Check Integrity ---
if [ ! -f "$DB_FILES" ]; then
    sqlite3 "$DB_FILES" "CREATE TABLE files (path TEXT PRIMARY KEY, mtime INTEGER, size INTEGER); CREATE TABLE metadata (key TEXT PRIMARY KEY, value INTEGER); INSERT INTO metadata VALUES ('last_run_time', 0);"
fi
if [ ! -f "$DB_FOLDERS" ]; then
    sqlite3 "$DB_FOLDERS" "CREATE TABLE folders (path TEXT PRIMARY KEY); CREATE TABLE metadata (key TEXT PRIMARY KEY, value INTEGER); INSERT INTO metadata VALUES ('last_run_time', 0);"
    FIRST_RUN=1
fi
if ! sqlite3 "$DB_FILES" "PRAGMA integrity_check;" | grep -q "ok"; then
    write_log "CRITICAL: File database integrity check failed. Aborting."
    cleanup_and_exit
fi
# --- Generate File Delta ---
if ! find "$SOURCE_DIR" "${FIND_EXCLUDE_ARGS[@]}" -type f -not -path "$LOG_DIR*" -printf '%p|%T@|%s\n' > "$CURRENT_FILES" 2> "$DB_DIR/find_error.log"; then
    write_log "Error running find: $(cat "$DB_DIR/find_error.log")"; cleanup_and_exit
fi
RELATIVE_SQL_CHANGED="SELECT substr(f.path, length('$SOURCE_DIR') + 1) AS path FROM files f LEFT JOIN files_last_run flr ON f.path = flr.path WHERE flr.path IS NULL OR f.mtime > COALESCE(flr.mtime, 0);"
RELATIVE_SQL_DELETED="SELECT substr(flr.path, length('$SOURCE_DIR') + 1) AS path FROM files_last_run flr WHERE flr.path NOT IN (SELECT path FROM files);"
if ! sqlite3 "$DB_FILES" <<SQL > /dev/null 2> "$DB_DIR/sqlite_error.log"
PRAGMA synchronous=OFF;
PRAGMA journal_mode=WAL;
BEGIN TRANSACTION;
DROP TABLE IF EXISTS files_new;
CREATE TABLE files_new (path TEXT PRIMARY KEY, mtime INTEGER, size INTEGER);
.mode list
.separator "|"
.import $CURRENT_FILES files_new
DROP TABLE IF EXISTS files;
ALTER TABLE files_new RENAME TO files;
CREATE INDEX IF NOT EXISTS idx_files_path ON files(path);
COMMIT;
BEGIN TRANSACTION;
CREATE TABLE IF NOT EXISTS files_last_run (path TEXT PRIMARY KEY, mtime INTEGER, size INTEGER);
.output $CHANGED_FILES
$RELATIVE_SQL_CHANGED
.output $DELETED_FILES
$RELATIVE_SQL_DELETED
COMMIT;
SQL
then
    write_log "Error SQLite files: $(cat "$DB_DIR/sqlite_error.log")"; cleanup_and_exit
fi
# --- Generate Folder Delta ---
if ! find "$SOURCE_DIR" "${FIND_EXCLUDE_ARGS[@]}" -type d -not -path "$LOG_DIR*" -printf '%p\n' | tr -d '\r' | sort -u > "$CURRENT_FOLDERS" 2> "$DB_DIR/find_error.log"; then
    write_log "Error running find folders"; cleanup_and_exit
fi
# Order deleted folders descending to delete deeply nested folders before their parents
RELATIVE_SQL_DELETED_FOLDERS="SELECT substr(flr.path, length('$SOURCE_DIR') + 1) AS path FROM folders_last_run flr WHERE flr.path NOT IN (SELECT path FROM folders) AND flr.path != '${SOURCE_DIR%/}' ORDER BY path DESC;"
# Order new folders ascending to create parent directories before subdirectories
RELATIVE_SQL_NEW_FOLDERS="SELECT substr(f.path, length('$SOURCE_DIR') + 1) AS path FROM folders f WHERE f.path NOT IN (SELECT path FROM folders_last_run) AND f.path != '${SOURCE_DIR%/}' ORDER BY path ASC;"
if ! sqlite3 "$DB_FOLDERS" <<SQL > /dev/null 2> "$DB_DIR/sqlite_error.log"
BEGIN TRANSACTION;
DROP TABLE IF EXISTS folders_new;
CREATE TABLE folders_new (path TEXT PRIMARY KEY);
.mode list
.separator "\t"
.import $CURRENT_FOLDERS folders_new
DROP TABLE IF EXISTS folders;
ALTER TABLE folders_new RENAME TO folders;
COMMIT;
BEGIN TRANSACTION;
CREATE TABLE IF NOT EXISTS folders_last_run (path TEXT PRIMARY KEY);
$( [ "$FIRST_RUN" -eq 0 ] && echo ".output $DELETED_FOLDERS" )
$( [ "$FIRST_RUN" -eq 0 ] && echo "$RELATIVE_SQL_DELETED_FOLDERS" )
.output $NEW_FOLDERS
$RELATIVE_SQL_NEW_FOLDERS
COMMIT;
SQL
then
    write_log "Error SQLite folders"; cleanup_and_exit
fi
# --- Proton Drive Native Operations ---
    # 1. Process File Deletions
    if [ -s "$DELETED_FILES" ]; then
        write_log "Processing file deletions..."
        while IFS= read -r rel_path; do
            [ -z "$rel_path" ] && continue
            target_remote_path="$REMOTE_DIR/$rel_path"
            if ! run_pd_cli_with_retry "$PD_CLI" filesystem trash "$target_remote_path"; then
                write_log "Failed to trash file: $target_remote_path"
                SYNC_ERROR=1
            fi
        done < "$DELETED_FILES"
    fi
    # 2. Process Folder Deletions
    if [ "$FIRST_RUN" -eq 0 ] && [ -s "$DELETED_FOLDERS" ]; then
        write_log "Processing folder deletions..."
                write_log "Failed to trash folder: $target_remote_path"
                SYNC_ERROR=1
            fi
        done < "$DELETED_FOLDERS"
    fi
    # API Stability Buffer
    if [ -s "$DELETED_FILES" ] || [ -s "$DELETED_FOLDERS" ]; then
        if [ -s "$CHANGED_FILES" ] || [ -s "$NEW_FOLDERS" ]; then
            sleep 5
        fi
    fi
    # 3. Process New Folder Creations
    if [ -s "$NEW_FOLDERS" ]; then
        write_log "Processing new folder creations..."
            parent_dir=$(dirname "$rel_path")
            folder_name=$(basename "$rel_path")
            # Format target parent directory
            if [ "$parent_dir" = "." ]; then
                target_parent="$REMOTE_DIR"
            else
                target_parent="$REMOTE_DIR/$parent_dir"
            fi
            if ! run_pd_cli_with_retry "$PD_CLI" filesystem create-folder "$target_parent" "$folder_name"; then
                # We do not set SYNC_ERROR=1 here because failure often just means the folder already exists.
                # If it truly failed to create, the file upload below will catch the error and flag it.
                write_log "Note: Folder creation failed or already exists: $target_parent/$folder_name"
            fi
        done < "$NEW_FOLDERS"
    fi
    # 4. Process File Uploads
    if [ -s "$CHANGED_FILES" ]; then
        write_log "Processing file uploads..."
            local_file="$SOURCE_DIR$rel_path"
            dir_name=$(dirname "$rel_path")
            # Format target directory string securely
            if [ "$dir_name" = "." ]; then
                target_remote_dir="$REMOTE_DIR"
            else
                target_remote_dir="$REMOTE_DIR/$dir_name"
            fi
            if ! run_pd_cli_with_retry "$PD_CLI" filesystem upload "$local_file" "$target_remote_dir" --conflict-strategy replace; then
                write_log "Failed to upload file: $local_file"
                SYNC_ERROR=1
            fi
        done < "$CHANGED_FILES"
    else
        write_log "No new or changed files to upload."
    fi
fi
# --- Final State Commit & Cleanup ---
if [ "$SYNC_ERROR" -eq 0 ]; then
    write_log "Operations successful. Committing state database."
    BEGIN TRANSACTION;
    DROP TABLE IF EXISTS files_last_run;
    ALTER TABLE files RENAME TO files_last_run;
    CREATE INDEX IF NOT EXISTS idx_files_last_run_path ON files_last_run(path);
    INSERT OR REPLACE INTO metadata (key, value) VALUES ('last_run_time', $(date +%s));
    COMMIT;
SQL
    BEGIN TRANSACTION;
    DROP TABLE IF EXISTS folders_last_run;
    ALTER TABLE folders RENAME TO folders_last_run;
    COMMIT;
SQL
    NEW_CHANGED_COUNT=$([ -f "$CHANGED_FILES" ] && wc -l < "$CHANGED_FILES" || echo 0)
    DELETED_COUNT=$([ -f "$DELETED_FILES" ] && wc -l < "$DELETED_FILES" || echo 0)
    DELETED_FOLDER_COUNT=0
    [ "$FIRST_RUN" -eq 0 ] && DELETED_FOLDER_COUNT=$([ -f "$DELETED_FOLDERS" ] && wc -l < "$DELETED_FOLDERS" || echo 0)
    log_footer "$NEW_CHANGED_COUNT" "$DELETED_COUNT" "$DELETED_FOLDER_COUNT"
else
    write_log "ERRORS detected during sync. Database state NOT updated. Will retry next run."
    echo "Errors detected. Check log." >&2
    exit 1
fi
# Upload the final log file to the remote
# Removed the extra trailing slash from the variable expansion
RELATIVE_LOG_PATH=$(dirname "${LOG_FILE#$SOURCE_DIR}")
if [ "$RELATIVE_LOG_PATH" = "." ]; then
    TARGET_LOG_DIR="$REMOTE_DIR"
else
    TARGET_LOG_DIR="$REMOTE_DIR/$RELATIVE_LOG_PATH"
fi
run_pd_cli_with_retry "$PD_CLI" filesystem upload "$LOG_FILE" "$TARGET_LOG_DIR" --conflict-strategy replace >/dev/null 2>&1
exit 0
Exclusion file:
# Exclusion list for folders only (individual files cannot be excluded)
# One rule per line. No quotes. No trailing slash needed.
# How it works:
# - The script strips trailing "/**" and trailing "/" if present.
# - It then uses: find -path "$SOURCE_DIR/<rule>" -prune
# Supported examples:
#   Backups Archive          → skips /mnt/YOURPOOL/Docs/Backups Archive and everything under it
#   Docs/Quicken Files       → skips that exact folder and its contents and subtree
#   Some Folder/**           → same as "Some Folder" (the /** is ignored)
# NOT properly supported:
#   **/Temp/**               → does not reliably match Temp folders anywhere in the tree
#   **/Something             → glob-style "anywhere" matching is not implemented
# Use simple relative paths from /mnt/YOURPOOL/Docs for reliable results.
# Lines starting with # and empty lines are ignored.
# MUST BE IN UNIX FORMAT FOR PROPER LINE ENDING
# /mnt/YOURPOOL/Docs/Docs/My Files/Home Assistant/Backups Archive
# /mnt/YOURPOOL/Docs/Docs/My Files/Accounting/Taxes
I got everything set up and went to run the cron job but it’s complaining about python in the trace, any idea what that’s about? I’m not super knowledgeable on how TrueNAS works so forgive me if I’m missing something obvious
Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/api/base/server/ws_handler/rpc.py", line 361, in process_method_call result = await method.call(app, id_, params) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/api/base/server/method.py", line 63, in call result = await result.wait(raise_error=True, raise_error_forward_classes=(Exception,)) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/job.py", line 475, in wait raise self.exc_info[1] File "/usr/lib/python3/dist-packages/middlewared/job.py", line 527, in run await self.future File "/usr/lib/python3/dist-packages/middlewared/job.py", line 574, in __run_body rv = await self.middleware.run_in_thread(self.method, *args) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/main.py", line 670, in run_in_thread return await self.run_in_executor(io_thread_pool_executor, method, *args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/main.py", line 667, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run result = self.fn(*self.args, **self.kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/api/base/decorator.py", line 116, in wrapped result = func(*args) ^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/plugins/cron.py", line 253, in run raise CallError(f'CronTask "{cron_cmd}" exited with {cp.returncode} (non-zero) exit status.') middlewared.service_exception.CallError: [EFAULT] CronTask "/mnt/BigData/home/proton_backupper/proton_file_tracker/SYNC_TO_PROTON.sh --timeout 12h > /dev/null 2>&1 > /dev/null" exited with 127 (non-zero) exit status.
I also originally tried to use proton drive cli version 7.0 but it complained about missing some packages like libsecret so i went back to 6.0 as you intended as opposed to wrecking my system using apt and the binary ran just fine.
System version 25.10.5 (latest as of August 5, 2026)
Nevermind, I simply had some directory variables misconfigured
(/mnt/BigData/home/proton_backupper was supposed to be /mnt/BigData/proton_backupper)
Thanks for the script! Exactly what I needed!
