Fast Dedup uses... magic?
I’m definitely trying that now. The NAS just seized up after about 40 kernel crashes in a row with 2 small rsync sessions running, and rebooted itself. It’s back up, and I’m trying again.
If I keep having to deal with these box resets/crashes, corrupting VMs that use the NAS as its datastore, I’ll have to stop using dedup altogether, it’s just too unpredictable and unstable, even when ARC is tuned/clamped down.
50% is not enough benefit for dedup to be worth it. And 64 GB RAM is not enough for classical dedup.
I made the mistake of enabling dedup on a dataset that was capped at 12 TB. Ran fine with 128 GB RAM; with “only” 64 GB RAM and no L2ARC, scrub slowed to a crawl. “5 GB per TB” and so on…
Atom C3000 does that. Xeon D-1500 does that, with enough PCIe lanes for a 3-way NVMe mirror for a dedup vdev, which you’d need WAY more than an Optane SLOG. (Unless you’re the last standing Itanium user…)
Why? CPU is about the least relevant part of a NAS. And “socketed server mini-ITX motherboard” is just asking for trouble. But here you are:
https://www.asrockrack.com/general/productdetail.asp?Model=X570D4I-2T#Specifications
:point_up:
Replying back with a large update.
After moving some datasets I had from dedup=on checksum=sha256 compression=zstd to dedup=off checksum=blake3 compression=zstd, and deleting the original source dataset, and moving one large dataset to a subdirectory under an existing dataset (collapsing 2 datasets into 1), I’ve managed to free up 9.2 terabytes of capacity.
Yes, that’s a real number. I thought I accidentally deleted a large dataset, but nothing I have is that large in a single dataset. There were no snapshots of these datasets, that was purely savings freed up from some pending backlog of async destroys finally freeing blocks on the pool.
Those must have been backlogged for the better part of 2 years. Even with multiple dozens of scrubs in that time, my capacity had been diminishing down to 11TB total free, now I have 21TB total free. Apparently the bptree was so backed up, it could never process the frees, and the rename old/create new/rsync old to new/destroy old, managed to shake it loose.
Instead of using dedup, I’m now going to use hardlink and jdupes inside each dataset to shed some of the duplicate files (there are millions of them) and see if that gives me even more capacity back.
I started with something that looked like this:
 dedup: DDT entries 88810794, size 28.4G on disk, 12.6G in core
bucket              allocated                       referenced
______   ______________________________   ______________________________
refcnt   blocks   LSIZE   PSIZE   DSIZE   blocks   LSIZE   PSIZE   DSIZE
     1    77.6M   10.5T   10.2T   10.2T    77.6M   10.5T   10.2T   10.2T
     2    6.38M    985G    954G    957G    13.3M   1.98T   1.92T   1.92T
     4     458K   48.0G   42.0G   42.9G    2.14M    224G    195G    199G
     8     136K   10.6G   7.55G   7.92G    1.38M    109G   76.7G   80.6G
    16    55.1K   4.17G   2.48G   2.65G    1.16M   89.7G   53.2G   56.8G
    32    29.9K   2.47G   1.07G   1.17G    1.26M    106G   44.2G   48.8G
    64    16.0K   1.50G    460M    517M    1.48M    147G   44.1G   49.4G
   128    5.07K    426M    140M    160M     902K   74.5G   24.5G   28.0G
   256    2.25K    171M   54.6M   63.0M     720K   49.3G   15.7G   18.4G
   512      466   14.5M   4.03M   6.17M     311K   9.84G   2.72G   4.16G
    1K      192   12.8M   2.46M   3.13M     293K   21.5G   4.00G   4.97G
    2K       74   4.04M    842K   1.08M     209K   11.4G   2.34G   3.09G
    4K       28    638K    210K    348K     150K   3.43G   1.14G   1.86G
    8K       16    500K    152K    227K     180K   5.80G   1.75G   2.58G
   16K        2     10K      7K   14.2K    41.4K    209M    145M    294M
   32K        3    128K     29K   42.6K     135K   6.11G   1.28G   1.91G
   64K        1   1.50K   1.50K   7.10K     120K    180M    180M    852M
  128K        1   11.5K      8K   14.2K     213K   2.40G   1.67G   2.96G
 Total    84.7M   11.5T   11.2T   11.2T     102M   13.3T   12.6T   12.6T
And right now, it’s still pruning, but I see this:
 dedup: DDT entries 83668274, size 27.2G on disk, 12.7G in core
     1    73.7M   10.1T   9.87T   9.87T    73.7M   10.1T   9.87T   9.87T
     2    5.78M    961G    935G    935G    11.9M   1.93T   1.88T   1.88T
     4     283K   44.1G   40.5G   40.6G    1.29M    203G    187G    188G
     8    60.4K   7.28G   6.60G   6.65G     612K   73.8G   66.5G   67.0G
    16    16.3K   1.91G   1.84G   1.85G     348K   40.9G   39.1G   39.4G
    32    4.19K    509M    454M    457M     156K   18.5G   16.4G   16.6G
    64      233   24.9M   24.3M   24.5M    20.3K   2.18G   2.13G   2.15G
   128      193   22.1M   21.7M   21.8M    34.1K   3.92G   3.84G   3.86G
   256       45   5.08M   4.59M   4.64M    14.0K   1.56G   1.39G   1.41G
   512        4   2.50K   2.50K   28.4K    2.65K   1.71M   1.71M   18.8M
    1K        2    128K   4.50K   14.2K    2.31K    130M   4.69M   16.4M
 Total    79.8M   11.1T   10.8T   10.8T    88.0M   12.4T   12.1T   12.1T
I learned quite a bit in this process about ARC, tuning, and why fast_dedup and dedup are basically the same, and neither are helpful at all.
Dedup was really holding your system here… :open_mouth:
And with just about 1 TB of data to deduplicate, it’s just not worth it. Well done!
:clap:
I’ll just leave this here.
DON'T CLICK ME
Taken from the meme thread.
I was seeing roughly 14% savings in a deduplicated vs. non-deduplicated dataset. Nothing to scoff at, worth the savings, but not worth the repeated oom-kill crashes at my capped memory ceiling. If I had 128GB memory in this box, I’d go for it. Sadly, I cannot.
I haven’t even reached the larger datasets to deduplicate (the bulk of those Ubuntu mirrors, probably 6TB of deduplicate’able data in a 10TB dataset), but it was crushing my system the more of those dataset mirrors I added to the DDT, so I had to rewind my work.
Paring it back to the smaller datasets helped, and keeping in mind that it’s block-based dedup, not file-based dedup, helped me re-rationalize its use.
Using compression=zstd and jdupes is gaining me more wins at this point.
Dedup is such a memory hog that it takes savings of 70% or more to make it “worth it”. 14% is nothing. And if you plan to fill that 50+ TB pool, you’d need 256+ GB RAM rather than 128 GB.
Can’t have one without the other. Unless you throw in A LOT more RAM or a dedup vdev.
Not sure why that would happen unless you don’t have sync always and a good slog…
As suggested in other threads, you would want to be seeing multiples, not fractions, to make de-dupe worth it.
If its 10-20%, just add another disk and call it a day.
If you can get 5-10x the data due to de-dupe maybe its worth pursuing.
