Hi all,
Bit of a noob here so please excuse if this sounds silly…
I installed truenas on decent home server. The server has a gpu and onboard gpu. Neither are showing up on the truenas gui.
The OS does seem to see the HW but its not listed in the system>advanced>gpu. Is there a config that I need to set to have truenas utilize these gpus?
ElectricEel-24.10.1
I tried to do some reading got some basic commands executed that might give some relevant information:
truenas_admin@truenas[~]$ sudo lspci | grep VGA
[sudo] password for truenas_admin:
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 630 (rev 04)
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Cape Verde GL [FirePro W4100]
truenas_admin@truenas[~]$ sudo lspci -k
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers (rev 05)
Subsystem: Dell Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers
Kernel driver in use: skl_uncore
00:01.0 PCI bridge: Intel Corporation 6th-10th Gen Core Processor PCIe Controller (x16) (rev 05)
Subsystem: Dell 6th-10th Gen Core Processor PCIe Controller (x16)
Kernel driver in use: pcieport
Subsystem: Dell HD Graphics 630
Kernel driver in use: i915
Kernel modules: i915
00:14.0 USB controller: Intel Corporation 100 Series/C230 Series Chipset Family USB 3.0 xHCI Controller (rev 31)
Subsystem: Dell 100 Series/C230 Series Chipset Family USB 3.0 xHCI Controller
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:14.2 Signal processing controller: Intel Corporation 100 Series/C230 Series Chipset Family Thermal Subsystem (rev 31)
Subsystem: Dell 100 Series/C230 Series Chipset Family Thermal Subsystem
Kernel driver in use: intel_pch_thermal
Kernel modules: intel_pch_thermal
00:16.0 Communication controller: Intel Corporation 100 Series/C230 Series Chipset Family MEI Controller #1 (rev 31)
Subsystem: Dell 100 Series/C230 Series Chipset Family MEI Controller
Kernel driver in use: mei_me
Kernel modules: mei_me
00:16.3 Serial controller: Intel Corporation 100 Series/C230 Series Chipset Family KT Redirection (rev 31)
Subsystem: Dell 100 Series/C230 Series Chipset Family KT Redirection
Kernel driver in use: serial
00:17.0 SATA controller: Intel Corporation Q170/Q150/B150/H170/H110/Z170/CM236 Chipset SATA Controller [AHCI Mode] (rev 31)
Subsystem: Dell Q170/Q150/B150/H170/H110/Z170/CM236 Chipset SATA Controller [AHCI Mode]
Kernel driver in use: ahci
Kernel modules: ahci
00:1b.0 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #17 (rev f1)
Subsystem: Dell 100 Series/C230 Series Chipset Family PCI Express Root Port
00:1d.0 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #9 (rev f1)
00:1f.0 ISA bridge: Intel Corporation C236 Chipset LPC/eSPI Controller (rev 31)
Subsystem: Dell C236 Chipset LPC/eSPI Controller
00:1f.2 Memory controller: Intel Corporation 100 Series/C230 Series Chipset Family Power Management Controller (rev 31)
Subsystem: Dell 100 Series/C230 Series Chipset Family Power Management Controller
00:1f.3 Audio device: Intel Corporation 100 Series/C230 Series Chipset Family HD Audio Controller (rev 31)
Subsystem: Dell 100 Series/C230 Series Chipset Family HD Audio Controller
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel, snd_soc_avs
00:1f.4 SMBus: Intel Corporation 100 Series/C230 Series Chipset Family SMBus (rev 31)
Subsystem: Dell 100 Series/C230 Series Chipset Family SMBus
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (2) I219-LM (rev 31)
Subsystem: Dell Ethernet Connection (2) I219-LM
Kernel driver in use: e1000e
Kernel modules: e1000e
Subsystem: Dell Cape Verde GL [FirePro W4100]
Kernel driver in use: radeon
Kernel modules: radeon, amdgpu
01:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000 Series]
Subsystem: Dell Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000 Series]
02:00.0 Non-Volatile memory controller: Sandisk Corp IX SN530 NVMe SSD (DRAM-less) (rev 01)
Subsystem: Sandisk Corp IX SN530 NVMe SSD (DRAM-less)
Kernel driver in use: nvme
Kernel modules: nvme
03:00.0 Network controller: Intel Corporation Wireless 8260 (rev 3a)
Subsystem: Intel Corporation Wireless 8260
truenas_admin@truenas[~]$ midclt call device.get_gpus | jq
“addr”: {
“pci_slot”: “0000:00:02.0”,
“domain”: “0000”,
“bus”: “00”,
“slot”: “02”
“description”: “Intel Corporation HD Graphics 630”,
“devices”: [
“pci_id”: “8086:591F”,
“pci_slot”: “0000:00:00.0”,
“vm_pci_slot”: “pci_0000_00_00_0”
“pci_id”: “8086:1901”,
“pci_slot”: “0000:00:01.0”,
“vm_pci_slot”: “pci_0000_00_01_0”
“pci_id”: “1002:682C”,
“pci_slot”: “0000:01:00.0”,
“vm_pci_slot”: “pci_0000_01_00_0”
“pci_id”: “1002:AAB0”,
“pci_slot”: “0000:01:00.1”,
“vm_pci_slot”: “pci_0000_01_00_1”
“pci_id”: “8086:5912”,
“vm_pci_slot”: “pci_0000_00_02_0”
“pci_id”: “8086:A12F”,
“pci_slot”: “0000:00:14.0”,
“vm_pci_slot”: “pci_0000_00_14_0”
“pci_id”: “8086:A131”,
“pci_slot”: “0000:00:14.2”,
“vm_pci_slot”: “pci_0000_00_14_2”
“pci_id”: “8086:A13A”,
“pci_slot”: “0000:00:16.0”,
“vm_pci_slot”: “pci_0000_00_16_0”
“pci_id”: “8086:A13D”,
“pci_slot”: “0000:00:16.3”,
“vm_pci_slot”: “pci_0000_00_16_3”
“pci_id”: “8086:A102”,
“pci_slot”: “0000:00:17.0”,
“vm_pci_slot”: “pci_0000_00_17_0”
“pci_id”: “8086:A167”,
“pci_slot”: “0000:00:1b.0”,
“vm_pci_slot”: “pci_0000_00_1b_0”
“pci_id”: “15B7:5007”,
“pci_slot”: “0000:02:00.0”,
“vm_pci_slot”: “pci_0000_02_00_0”
“pci_id”: “8086:A118”,
“pci_slot”: “0000:00:1d.0”,
“vm_pci_slot”: “pci_0000_00_1d_0”
“pci_id”: “8086:24F3”,
“pci_slot”: “0000:03:00.0”,
“vm_pci_slot”: “pci_0000_03_00_0”
“pci_id”: “8086:A149”,
“pci_slot”: “0000:00:1f.0”,
“vm_pci_slot”: “pci_0000_00_1f_0”
“pci_id”: “8086:A121”,
“pci_slot”: “0000:00:1f.2”,
“vm_pci_slot”: “pci_0000_00_1f_2”
“pci_id”: “8086:A170”,
“pci_slot”: “0000:00:1f.3”,
“vm_pci_slot”: “pci_0000_00_1f_3”
“pci_id”: “8086:A123”,
“pci_slot”: “0000:00:1f.4”,
“vm_pci_slot”: “pci_0000_00_1f_4”
“pci_id”: “8086:15B7”,
“pci_slot”: “0000:00:1f.6”,
“vm_pci_slot”: “pci_0000_00_1f_6”
“vendor”: “INTEL”,
“uses_system_critical_devices”: true,
“critical_reason”: “Critical devices found: 0000:00:1f.0, 0000:00:1b.0, 0000:00:01.0, 0000:00:1d.0, 0000:00:1f.4\nCritical devices found in same IOMMU group: 0000:00:1f.0, 0000:00:1b.0, 0000:01:00.1, 0000:00:01.0, 0000:00:1f.3, 0000:00:1d.0, 0000:01:00.0, 0000:00:1f.2, 0000:00:1f.4”,
“available_to_host”: true
“addr”: {
“domain”: “0000”,
“bus”: “01”,
“slot”: “00”
“description”: “Advanced Micro Devices, Inc. [AMD/ATI] Cape Verde GL [FirePro W4100]”,
“devices”: [
“vendor”: “AMD”,
“critical_reason”: “Critical devices found in same IOMMU group: 0000:01:00.1, 0000:01:00.0”,
truenas_admin@truenas[~]$ sudo sudo midclt call app.gpu_choices | jq
“0000:00:02.0”: {
“vendor”: “INTEL”,
“vendor_specific_config”: {},
“0000:01:00.0”: {
“vendor”: “AMD”,
