Help identifying dead disk
I have a pool that is unhealthy, but still available. I’m pretty certain, but as my skills are low in the trunas world, I wanted to be 100% sure it’s ada2 that needs reaplacing. But it seems obvious to me.
it’s missing from the disks to
So I’m going to replace it, but why is it in the pool still, and the pool “works”
Thanks
First of all, it is not obvious to me that the drive has failed. This could be a ZFS issue and the drive is fine. Look in my link below for the Drive Troubleshooting Charts. I am working on a more spread out version but all the questions are in this set of charts.
Ask if you have any questions.
Thanks Joe,
It appears I have a problem drive or pool. I have a replacement drive, so I’ll delete the pool, replace ada2, recreate the pool and copy the data back.
belt and braces, that should fix it :slight_smile:
Thanks
