Help recovering zfs pool after VM passthrough on proxmox
@HoneyBadger I did this:
# zdb -e -bcsvL datatank
10.9T completed (  86MB/s) estimated time remaining: 4hr 32min 51sec         cbc
Traversing all blocks to verify checksums ...
zdb_blkptr_cb: Got error 52 reading <0, 0, 0, 48d> DVA[0]=<0:b2b011ee000:1000> DVA[1]=<0:627512f000:1000> DVA[2]=<0:16190579000:1000> [L0 DMU dnode] fletcher4 lz4 unencrypted LE contiguous unique triple size=4000L/1000P birth=15489506L/15489506P fill=6 cksum=00000033cfab9dad:0000bb89c5773c43:0154eb3d0fa607e0:9efc5bfdadc50569 -- skipping
zdb_blkptr_cb: Got error 52 reading <0, 0, 0, ed3> DVA[0]=<0:b2b014e6000:1000> DVA[1]=<0:63006b6000:1000> DVA[2]=<0:16300156000:1000> [L0 DMU dnode] fletcher4 lz4 unencrypted LE contiguous unique triple size=4000L/1000P birth=15489510L/15489510P fill=5 cksum=00000033fb3b041c:0000bf13557f068a:0160d50a122f0178:b45d716c116f0e1a -- skipping
zdb_blkptr_cb: Got error 52 reading <0, 0, 0, ed6> DVA[0]=<0:b2b014e7000:1000> DVA[1]=<0:63006b7000:1000> DVA[2]=<0:16300157000:1000> [L0 DMU dnode] fletcher4 lz4 unencrypted LE contiguous unique triple size=4000L/1000P birth=15489510L/15489510P fill=6 cksum=0000003fb735b76c:0000e5e4ed8f80be:01a0dbff71baa88e:fa78d8051e3db0ce -- skipping
zdb_blkptr_cb: Got error 52 reading <23189, 0, -1, 0> DVA[0]=<0:b2b0123a000:1000> DVA[1]=<0:6300421000:1000> [L0 DMU objset] fletcher4 uncompressed unencrypted LE contiguous unique double size=1000L/1000P birth=15489507L/15489507P fill=2 cksum=000000058454d62e:000014227c2aed71:0024ef2eed625948:2d662b7e33fe764d -- skipping
Error counts:
        errno  count
           52  4
        bp count:             105560728
        ganged count:                 0
        bp logical:      12095475617792      avg: 114583
        bp physical:     11924163283456      avg: 112960     compression:   1.01
        bp allocated:    11932194775040      avg: 113036     compression:   1.01
        bp deduped:                   0    ref>1:      0   deduplication:   1.00
        bp cloned:                    0    count:      0
        Normal class:    13415743545344     used: 96.05%
        Embedded log class     2017865728     used: 11.75%
        additional, non-pointer bps of type 0:      23606
        Dittoed blocks on same vdev: 793631
        Dittoed blocks in same metaslab: 9
        indirect vdev id 1 has 96044 segments (93.8K in memory)
        indirect vdev id 2 has 879320 segments (859K in memory)
Blocks  LSIZE   PSIZE   ASIZE     avg    comp   %Total  Type
     -      -       -       -       -       -        -  unallocated
     2    32K     12K     36K     18K    2.67     0.00  object directory
    14  38.5K   10.5K    168K     12K    3.67     0.00  object array
     1    16K      4K     12K     12K    4.00     0.00  packed nvlist
     -      -       -       -       -       -        -  packed nvlist size
 48.9K  6.09G    399M   1.17G   24.5K   15.65     0.01  bpobj
     -      -       -       -       -       -        -  bpobj header
     -      -       -       -       -       -        -  SPA space map header
 3.55K   365M    161M    483M    136K    2.27     0.00  SPA space map
     4   160K    160K    160K     40K    1.00     0.00  ZIL intent log
 28.1K   518M    117M    235M   8.35K    4.44     0.00  DMU dnode
   112   448K    448K    900K   8.04K    1.00     0.00  DMU objset
     -      -       -       -       -       -        -  DSL directory
    67  34.5K      4K     72K   1.07K    8.62     0.00  DSL directory child map
    71   226K   57.5K    276K   3.89K    3.92     0.00  DSL dataset snap map
    98  1016K    260K    888K   9.06K    3.91     0.00  DSL props
     -      -       -       -       -       -        -  DSL dataset
     -      -       -       -       -       -        -  ZFS znode
     -      -       -       -       -       -        -  ZFS V0 ACL
 86.9M  10.8T   10.6T   10.6T    125K    1.01    98.06  ZFS plain file
 60.5K   706M    185M    463M   7.65K    3.82     0.00  ZFS directory
    43    32K     32K    344K      8K    1.00     0.00  ZFS master node
   105   172K      8K     16K     156   21.44     0.00  ZFS delete queue
 13.6M   219G    213G    213G   15.6K    1.03     1.92  zvol object
     -      -       -       -       -       -        -  zvol prop
     -      -       -       -       -       -        -  other uint8[]
     -      -       -       -       -       -        -  other uint64[]
     -      -       -       -       -       -        -  other ZAP
     -      -       -       -       -       -        -  persistent error log
   106  13.2M   1.43M   4.28M   41.3K    9.23     0.00  SPA history
     -      -       -       -       -       -        -  SPA history offsets
     -      -       -       -       -       -        -  Pool properties
     -      -       -       -       -       -        -  DSL permissions
     -      -       -       -       -       -        -  ZFS ACL
     -      -       -       -       -       -        -  ZFS SYSACL
     -      -       -       -       -       -        -  FUID table
     -      -       -       -       -       -        -  FUID table size
    23  15.5K   4.50K     24K   1.04K    3.44     0.00  DSL dataset next clones
     -      -       -       -       -       -        -  scan work queue
   315   168K   17.5K    104K     338    9.63     0.00  ZFS user/group/project used
     -      -       -       -       -       -        -  ZFS user/group/project quota
     -      -       -       -       -       -        -  snapshot refcount tags
     -      -       -       -       -       -        -  DDT ZAP algorithm
     -      -       -       -       -       -        -  DDT statistics
    59  29.5K   29.5K    472K      8K    1.00     0.00  System attributes
     -      -       -       -       -       -        -  SA master node
    43  64.5K   64.5K    344K      8K    1.00     0.00  SA attr registration
   110  1.72M    440K    880K      8K    4.00     0.00  SA attr layouts
     -      -       -       -       -       -        -  scan translations
     -      -       -       -       -       -        -  deduplicated block
   210   260K    151K    804K   3.83K    1.72     0.00  DSL deadlist map
     -      -       -       -       -       -        -  DSL deadlist map hdr
     2     5K   4.50K     24K     12K    1.11     0.00  DSL dir clones
     1   128K      4K     12K     12K   32.00     0.00  bpobj subobj
     -      -       -       -       -       -        -  deferred free
     -      -       -       -       -       -        -  dedup ditto
   487  28.8M   12.0M   36.6M   77.0K    2.39     0.00  other
  101M  11.0T   10.8T   10.9T    110K    1.01   100.00  Total
  894K  32.1G   6.55G   13.7G   15.7K    4.90     0.12  Metadata Total
Block Size Histogram
  block   psize                lsize                asize
   size   Count   Size   Cum.  Count   Size   Cum.  Count   Size   Cum.
    512:  27.7K  13.9M  13.9M  27.7K  13.9M  13.9M      0      0      0
     1K:  37.1K  45.9M  59.7M  37.1K  45.9M  59.7M      0      0      0
     2K:  33.0K  86.4M   146M  33.0K  86.4M   146M      0      0      0
     4K:   795K  3.11G  3.25G  21.7K   117M   263M   417K  1.63G  1.63G
     8K:  1.15M  12.3G  15.6G  14.5K   161M   424M  1.22M  11.6G  13.2G
    16K:  12.9M   208G   223G  13.7M   219G   219G  13.3M   217G   230G
    32K:   444K  20.8G   244G   771K  24.4G   243G   442K  20.6G   251G
    64K:  1.60M   153G   397G  23.1K  2.00G   245G  1.61M   153G   404G
   128K:  83.7M  10.5T  10.8T  86.1M  10.8T  11.0T  83.7M  10.5T  10.9T
   256K:      0      0  10.8T      0      0  11.0T  1.14K   319M  10.9T
   512K:      0      0  10.8T      0      0  11.0T      0      0  10.9T
     1M:      0      0  10.8T      0      0  11.0T      0      0  10.9T
     2M:      0      0  10.8T      0      0  11.0T      0      0  10.9T
     4M:      0      0  10.8T      0      0  11.0T      0      0  10.9T
     8M:      0      0  10.8T      0      0  11.0T      0      0  10.9T
    16M:      0      0  10.8T      0      0  11.0T      0      0  10.9T
                            capacity   operations   bandwidth  ---- errors ----
description                used avail  read write  read write  read write cksum
datatank                  12.2T  528G 2.14K     0  254M     0     0     0     0
  mirror                  12.2T  528G 2.14K     0  254M     0     0     0     0
    /dev/sde2                         1.07K     0  126M     0     0     0   137
    /dev/sdd2                         1.07K     0  127M     0     0     0   137
  indirect                                0     0     0     0     0     0     0
Is it helpful?
Running a forced import on half of the mirror just gives me a null pointer dereference from the kernel, then zpool seems to do nothing forever:
# zpool import -d /dev/sde2 datatank -fFX
Yeah, unfortunately there’s likely severe metadata corruption from the double-mount.
Try dumping a full label list including uberblocks with zdb -ul /dev/sde2 and we can see about trying to spelunk for one to use with -T (probably just “pick the earliest available option”) but if it was double-mounted for long enough to rotate through all 32 available positions then it’s been pretty scrambled.
Here is what I get:
# zdb -ul /dev/sde2
LABEL 0
    version: 5000
    state: 0
    txg: 15493413
    pool_guid: 16911827047402167892
    errata: 0
    hostid: 383395800
    hostname: 'datatank'
    top_guid: 11077806832579153414
    guid: 8569546290774946668
    vdev_children: 3
    vdev_tree:
        type: 'mirror'
        whole_disk: 0
        metaslab_array: 65
        metaslab_shift: 34
        ashift: 12
        asize: 13998367178752
        is_log: 0
        create_txg: 4
        children[0]:
            type: 'disk'
            path: '/dev/sdb'
            devid: 'scsi-0QEMU_QEMU_HARDDISK_drive-scsi2'
            phys_path: 'pci-0000:01:03.0-scsi-0:0:0:2'
            whole_disk: 1
            DTL: 21406
            create_txg: 4
        children[1]:
            type: 'disk'
            guid: 13180809383598811762
            path: '/dev/sda'
            devid: 'scsi-0QEMU_QEMU_HARDDISK_drive-scsi1'
            phys_path: 'pci-0000:01:02.0-scsi-0:0:0:1'
            vdev_enc_sysfs_path: '/sys/class/enclosure/6:0:0:0/Slot 05'
            whole_disk: 1
            DTL: 9036
            create_txg: 4
    features_for_read:
        com.delphix:hole_birth
        com.delphix:embedded_data
        com.delphix:device_removal
        com.klarasystems:vdev_zaps_v2
    labels = 0 1 2 3
    Uberblock[0]
        magic = 0000000000bab10c
        version = 5000
        txg = 15493440
        guid_sum = 15792786418798772495
        timestamp = 1759868137 UTC = Tue Oct  7 22:15:37 2025
        bp = DVA[0]=<0:16300a6f000:1000> DVA[1]=<0:6309578000:1000> DVA[2]=<0:237c920d000:1000> [L0 DMU objset] fletcher4 uncompressed unencrypted LE contiguous unique triple size=1000L/1000P birth=15493440L/15493440P fill=2677 cksum=00000003e04a8997:00000efb17f68653:001cfb6936b50236:256bd57a629cdbbe
        mmp_magic = 00000000a11cea11
        mmp_delay = 0
        mmp_valid = 0
        checkpoint_txg = 0
        raidz_reflow state=0 off=0
        labels = 0 1 2 3
    Uberblock[1]
        version = 5000
        txg = 15493473
        timestamp = 1759868367 UTC = Tue Oct  7 22:19:27 2025
        bp = DVA[0]=<0:b2b016a1000:1000> DVA[1]=<0:63073f0000:1000> DVA[2]=<0:16300346000:1000> [L0 DMU objset] fletcher4 uncompressed unencrypted LE contiguous unique triple size=1000L/1000P birth=15493473L/15493473P fill=2680 cksum=000000047c3f1f11:00001153776d77f8:0021805f61411d90:2b3beee9623d0272
        mmp_delay = 0
        mmp_valid = 0
        checkpoint_txg = 0
        labels = 0 1 2 3
    Uberblock[2]
        version = 5000
        txg = 15493602
        timestamp = 1759869028 UTC = Tue Oct  7 22:30:28 2025
        bp = DVA[0]=<0:b2b01729000:1000> DVA[1]=<0:6307a1b000:1000> DVA[2]=<0:163003ea000:1000> [L0 DMU objset] fletcher4 uncompressed unencrypted LE contiguous unique triple size=1000L/1000P birth=15493602L/15493602P fill=2682 cksum=000000051073f296:0000138a36118842:0025bd1a77c917e4:30a570a37eea995f
        mmp_delay = 0
        mmp_valid = 0
        checkpoint_txg = 0
        labels = 0 1 2 3
    Uberblock[3]
        version = 5000
        txg = 15493443
        timestamp = 1759868138 UTC = Tue Oct  7 22:15:38 2025
        bp = DVA[0]=<0:16303310000:1000> DVA[1]=<0:6309634000:1000> DVA[2]=<0:237c9d07000:1000> [L0 DMU objset] fletcher4 uncompressed unencrypted LE contiguous unique triple size=1000L/1000P birth=15493443L/15493443P fill=2679 cksum=00000003c3787efd:00000e8a65863529:001c1ef141800285:244c2090c161dc08
        mmp_delay = 0
        mmp_valid = 0
        checkpoint_txg = 0
        labels = 0 1 2 3
    Uberblock[4]
        version = 5000
        txg = 15493476
        timestamp = 1759868383 UTC = Tue Oct  7 22:19:43 2025
        bp = DVA[0]=<0:b2b016c8000:1000> DVA[1]=<0:630795d000:1000> DVA[2]=<0:16300369000:1000> [L0 DMU objset] fletcher4 uncompressed unencrypted LE contiguous unique triple size=1000L/1000P birth=15493476L/15493476P fill=2681 cksum=000000051c433cef:000013ba0f4edb14:00261dd7a16cc525:31279be5ab9b2011
        mmp_delay = 0
        mmp_valid = 0
        checkpoint_txg = 0
        labels = 0 1 2 3
    Uberblock[5]
        version = 5000
        txg = 15493477
        timestamp = 1759868388 UTC = Tue Oct  7 22:19:48 2025
        bp = DVA[0]=<0:b2b0170f000:1000> DVA[1]=<0:63079f7000:1000> DVA[2]=<0:163003c9000:1000> [L0 DMU objset] fletcher4 uncompressed unencrypted LE contiguous unique triple size=1000L/1000P birth=15493477L/15493477P fill=2681 cksum=000000055d76b06d:000014b404286a23:0027fd7538b3eb06:338dc408e0dde1ba
        mmp_delay = 0
        mmp_valid = 0
        checkpoint_txg = 0
        labels = 0 1 2 3
    Uberblock[6]
        version = 5000
        txg = 15493446
        timestamp = 1759868139 UTC = Tue Oct  7 22:15:39 2025
        bp = DVA[0]=<0:16303fa8000:1000> DVA[1]=<0:630970d000:1000> DVA[2]=<0:237bf8e1000:1000> [L0 DMU objset] fletcher4 uncompressed unencrypted LE contiguous unique triple size=1000L/1000P birth=15493446L/15493446P fill=2677 cksum=00000002f6ab5970:00000b789b49604b:001639ebd04e8716:1cbe35fa0573eeb9
        mmp_delay = 0
        mmp_valid = 0
        checkpoint_txg = 0
        labels = 0 1 2 3
    Uberblock[7]
        version = 5000
        txg = 15493447
        timestamp = 1759868140 UTC = Tue Oct  7 22:15:40 2025
        bp = DVA[0]=<0:163049e5000:1000> DVA[1]=<0:630972c000:1000> DVA[2]=<0:237c9d6d000:1000> [L0 DMU objset] fletcher4 uncompressed unencrypted LE contiguous unique triple size=1000L/1000P birth=15493447L/15493447P fill=2677 cksum=00000003615ef27e:00000d119ff10dbf:00194aad36eed909:20ab057cf25a5124
        mmp_delay = 0
        mmp_valid = 0
        checkpoint_txg = 0
        labels = 0 1 2 3
    Uberblock[8]
        version = 5000
        txg = 15493448
        bp = DVA[0]=<0:16304a37000:1000> DVA[1]=<0:6309e26000:1000> DVA[2]=<0:2378b7f6000:1000> [L0 DMU objset] fletcher4 uncompressed unencrypted LE contiguous unique triple size=1000L/1000P birth=15493448L/15493448P fill=2678 cksum=00000003dc4fef7d:00000ee801d1b41d:001ccf72119eedad:252a263137ca05a2
        mmp_delay = 0
        mmp_valid = 0
        checkpoint_txg = 0
        labels = 0 1 2 3
    Uberblock[9]
        version = 5000
        txg = 15493449
        bp = DVA[0]=<0:16304a59000:1000> DVA[1]=<0:6309e38000:1000> DVA[2]=<0:237f2b2a000:1000> [L0 DMU objset] fletcher4 uncompressed unencrypted LE contiguous unique triple size=1000L/1000P birth=15493449L/15493449P fill=2679 cksum=00000003d98c3bdd:00000edc2387c91f:001cb63e74154f15:2506c78bbd1f4946
        mmp_delay = 0
        mmp_valid = 0
        checkpoint_txg = 0
        labels = 0 1 2 3
    Uberblock[10]
        version = 5000
        txg = 15493610
        timestamp = 1759869069 UTC = Tue Oct  7 22:31:09 2025
        bp = DVA[0]=<0:b2b0175c000:1000> DVA[1]=<0:6308243000:1000> DVA[2]=<0:16300430000:1000> [L0 DMU objset] fletcher4 uncompressed unencrypted LE contiguous unique triple size=1000L/1000P birth=15493610L/15493610P fill=2682 cksum=000000048b6aee34:0000118da5e9a825:0021f00db219cfc3:2bcaffce610bfc0c
        mmp_delay = 0
        mmp_valid = 0
        checkpoint_txg = 0
        labels = 0 1 2 3
    Uberblock[11]
        version = 5000
        txg = 15493611
        timestamp = 1759869074 UTC = Tue Oct  7 22:31:14 2025
        bp = DVA[0]=<0:b2b01773000:1000> DVA[1]=<0:630827a000:1000> DVA[2]=<0:16300450000:1000> [L0 DMU objset] fletcher4 uncompressed unencrypted LE contiguous unique triple size=1000L/1000P birth=15493611L/15493611P fill=2682 cksum=0000000430f94d9a:000010354a88b6c0:001f5fdc345f2726:288893ac868da29b
        mmp_delay = 0
        mmp_valid = 0
        checkpoint_txg = 0
        labels = 0 1 2 3
    Uberblock[12]
        version = 5000
        txg = 15493452
        timestamp = 1759868142 UTC = Tue Oct  7 22:15:42 2025
        bp = DVA[0]=<0:163056b9000:1000> DVA[1]=<0:6309ecb000:1000> DVA[2]=<0:237c9451000:1000> [L0 DMU objset] fletcher4 uncompressed unencrypted LE contiguous unique triple size=1000L/1000P birth=15493452L/15493452P fill=2682 cksum=00000002d12aaff7:00000ae9eef3fae1:00152a44ace2bedf:1b650e19241f1e3b
        mmp_delay = 0
        mmp_valid = 0
        checkpoint_txg = 0
        labels = 0 1 2 3
    Uberblock[13]
        version = 5000
        txg = 15493613
        timestamp = 1759869084 UTC = Tue Oct  7 22:31:24 2025
        bp = DVA[0]=<0:b2b017ac000:1000> DVA[1]=<0:63086b1000:1000> DVA[2]=<0:16300475000:1000> [L0 DMU objset] fletcher4 uncompressed unencrypted LE contiguous unique triple size=1000L/1000P birth=15493613L/15493613P fill=2682 cksum=00000003843cdb99:00000d9d67391cfb:001a62c6fc25af88:2221242bcd079672
        mmp_delay = 0
        mmp_valid = 0
        checkpoint_txg = 0
        labels = 0 1 2 3
    Uberblock[14]
        version = 5000
        txg = 15493454
        bp = DVA[0]=<0:16305909000:1000> DVA[1]=<0:6309f46000:1000> DVA[2]=<0:b2b01898000:1000> [L0 DMU objset] fletcher4 uncompressed unencrypted LE contiguous unique triple size=1000L/1000P birth=15493454L/15493454P fill=2682 cksum=0000000499822a14:000011c857375144:002269b1263b99c4:2c726079e31f838e
        mmp_delay = 0
        mmp_valid = 0
        checkpoint_txg = 0
        labels = 0 1 2 3
    Uberblock[15]
        version = 5000
        txg = 15493455
        timestamp = 1759868143 UTC = Tue Oct  7 22:15:43 2025
        bp = DVA[0]=<0:16306eb3000:1000> DVA[1]=<0:6309f73000:1000> DVA[2]=<0:b2b018cb000:1000> [L0 DMU objset] fletcher4 uncompressed unencrypted LE contiguous unique triple size=1000L/1000P birth=15493455L/15493455P fill=2683 cksum=000000040373ed2e:00000f8826d63355:001e16564416165f:26e6278cc38c2a5e
        mmp_delay = 0
        mmp_valid = 0
        checkpoint_txg = 0
        labels = 0 1 2 3
    Uberblock[16]
        version = 5000
        txg = 15493456
        timestamp = 1759868280 UTC = Tue Oct  7 22:18:00 2025
        bp = DVA[0]=<0:b2b0164b000:1000> DVA[1]=<0:6307392000:1000> DVA[2]=<0:163002ec000:1000> [L0 DMU objset] fletcher4 uncompressed unencrypted LE contiguous unique triple size=1000L/1000P birth=15493456L/15493456P fill=2678 cksum=000000042add874f:0000101d5418afdc:001f30d46dec56a3:284b004b3e651523
        mmp_delay = 0
        mmp_valid = 0
        checkpoint_txg = 0
        labels = 0 1 2 3
    Uberblock[17]
        version = 5000
        txg = 15493457
        timestamp = 1759868285 UTC = Tue Oct  7 22:18:05 2025
        bp = DVA[0]=<0:b2b01674000:1000> DVA[1]=<0:63073cb000:1000> DVA[2]=<0:16300316000:1000> [L0 DMU objset] fletcher4 uncompressed unencrypted LE contiguous unique triple size=1000L/1000P birth=15493457L/15493457P fill=2679 cksum=00000004ca7b11bb:0000127f66aba9e4:0023bfe9e03dbdab:2e1cf61e4ac6c678
        mmp_delay = 0
        mmp_valid = 0
        checkpoint_txg = 0
        labels = 0 1 2 3
    Uberblock[18]
        version = 5000
        txg = 15493458
        timestamp = 1759868144 UTC = Tue Oct  7 22:15:44 2025
        bp = DVA[0]=<0:16306fbe000:1000> DVA[1]=<0:630a017000:1000> DVA[2]=<0:b2b01983000:1000> [L0 DMU objset] fletcher4 uncompressed unencrypted LE contiguous unique triple size=1000L/1000P birth=15493458L/15493458P fill=2685 cksum=000000043b5f48fc:0000105bef7fbc89:001fa7ba6b94abaf:28e1c1dda97b754b
        mmp_delay = 0
        mmp_valid = 0
        checkpoint_txg = 0
        labels = 0 1 2 3
    Uberblock[19]
        version = 5000
        txg = 15493427
        timestamp = 1759868133 UTC = Tue Oct  7 22:15:33 2025
        bp = DVA[0]=<0:163004d2000:1000> DVA[1]=<0:6308ade000:1000> DVA[2]=<0:237c9d6d000:1000> [L0 DMU objset] fletcher4 uncompressed unencrypted LE contiguous unique triple size=1000L/1000P birth=15493427L/15493427P fill=2684 cksum=0000000433b05152:00001037cc14b7f8:001f55528d3c8af8:286731eee1a36224
        mmp_delay = 0
        mmp_valid = 0
        checkpoint_txg = 0
        labels = 0 1 2 3
    Uberblock[20]
        version = 5000
        txg = 15493428
        bp = DVA[0]=<0:163004f6000:1000> DVA[1]=<0:6308b29000:1000> DVA[2]=<0:237a129f000:1000> [L0 DMU objset] fletcher4 uncompressed unencrypted LE contiguous unique triple size=1000L/1000P birth=15493428L/15493428P fill=2684 cksum=00000003460f1e3b:00000ca905bb0c1c:00188227bff6806f:1faa7c9a399e2a69
        mmp_delay = 0
        mmp_valid = 0
        checkpoint_txg = 0
        labels = 0 1 2 3
    Uberblock[21]
        version = 5000
        txg = 15493429
        timestamp = 1759868134 UTC = Tue Oct  7 22:15:34 2025
        bp = DVA[0]=<0:1630054a000:1000> DVA[1]=<0:6308b6e000:1000> DVA[2]=<0:237c9d3e000:1000> [L0 DMU objset] fletcher4 uncompressed unencrypted LE contiguous unique triple size=1000L/1000P birth=15493429L/15493429P fill=2684 cksum=00000004aa5db128:000012007283fb06:0022c4c3f7e54aef:2cd174578806c4de
        mmp_delay = 0
        mmp_valid = 0
        checkpoint_txg = 0
        labels = 0 1 2 3
    Uberblock[22]
        version = 5000
        txg = 15493430
        timestamp = 1759868147 UTC = Tue Oct  7 22:15:47 2025
        bp = DVA[0]=<0:b2b015a6000:1000> DVA[1]=<0:630729c000:1000> DVA[2]=<0:16300220000:1000> [L0 DMU objset] fletcher4 uncompressed unencrypted LE contiguous unique triple size=1000L/1000P birth=15493430L/15493430P fill=2677 cksum=00000003b9a92519:00000e69ae45e1f6:001be9bb4a78a061:2414773366a6fcc8
        mmp_delay = 0
        mmp_valid = 0
        checkpoint_txg = 0
        labels = 0 1 2 3
    Uberblock[23]
        version = 5000
        txg = 15493431
        bp = DVA[0]=<0:163005e4000:1000> DVA[1]=<0:6308c69000:1000> DVA[2]=<0:237c9ca1000:1000> [L0 DMU objset] fletcher4 uncompressed unencrypted LE contiguous unique triple size=1000L/1000P birth=15493431L/15493431P fill=2681 cksum=0000000390de4bd4:00000dc60f88771e:001aa1b87e9f950b:225e38a7a88959a7
        mmp_delay = 0
        mmp_valid = 0
        checkpoint_txg = 0
        labels = 0 1 2 3
    Uberblock[24]
        version = 5000
        txg = 15493432
        timestamp = 1759868135 UTC = Tue Oct  7 22:15:35 2025
        bp = DVA[0]=<0:1630072a000:1000> DVA[1]=<0:6308dc2000:1000> DVA[2]=<0:237b195d000:1000> [L0 DMU objset] fletcher4 uncompressed unencrypted LE contiguous unique triple size=1000L/1000P birth=15493432L/15493432P fill=2682 cksum=000000031896d908:00000bfc9837e766:00173aea00056665:1e0c108b85b7bcd5
        mmp_delay = 0
        mmp_valid = 0
        checkpoint_txg = 0
        labels = 0 1 2 3
    Uberblock[25]
        version = 5000
        txg = 15493433
        timestamp = 1759868162 UTC = Tue Oct  7 22:16:02 2025
        bp = DVA[0]=<0:b2b015d0000:1000> DVA[1]=<0:63072c6000:1000> DVA[2]=<0:1630024e000:1000> [L0 DMU objset] fletcher4 uncompressed unencrypted LE contiguous unique triple size=1000L/1000P birth=15493433L/15493433P fill=2678 cksum=000000045cedbb4c:000010da234123d3:002095240847b0c4:2a0b9d4373dbb2a1
        mmp_delay = 0
        mmp_valid = 0
        checkpoint_txg = 0
        labels = 0 1 2 3
    Uberblock[26]
        version = 5000
        txg = 15493434
        timestamp = 1759868168 UTC = Tue Oct  7 22:16:08 2025
        bp = DVA[0]=<0:b2b0160e000:1000> DVA[1]=<0:63072f5000:1000> DVA[2]=<0:16300289000:1000> [L0 DMU objset] fletcher4 uncompressed unencrypted LE contiguous unique triple size=1000L/1000P birth=15493434L/15493434P fill=2677 cksum=00000004344ee74b:00001042b1139a99:001f7abf6c9a9ba2:28ac7f4bc3ff5a88
        mmp_delay = 0
        mmp_valid = 0
        checkpoint_txg = 0
        labels = 0 1 2 3
    Uberblock[27]
        version = 5000
        txg = 15493435
        timestamp = 1759868136 UTC = Tue Oct  7 22:15:36 2025
        bp = DVA[0]=<0:1630086e000:1000> DVA[1]=<0:6308f95000:1000> DVA[2]=<0:237c9d6d000:1000> [L0 DMU objset] fletcher4 uncompressed unencrypted LE contiguous unique triple size=1000L/1000P birth=15493435L/15493435P fill=2676 cksum=00000004893838cd:0000117f50518d42:0021c90a16c8b8dc:2b8a1451654ee657
        mmp_delay = 0
        mmp_valid = 0
        checkpoint_txg = 0
        labels = 0 1 2 3
    Uberblock[28]
        version = 5000
        txg = 15493436
        timestamp = 1759868178 UTC = Tue Oct  7 22:16:18 2025
        bp = DVA[0]=<0:b2b01625000:1000> DVA[1]=<0:6307343000:1000> DVA[2]=<0:163002b2000:1000> [L0 DMU objset] fletcher4 uncompressed unencrypted LE contiguous unique triple size=1000L/1000P birth=15493436L/15493436P fill=2678 cksum=00000004539e9ebf:000010b7eebcf14b:002056597e23c3bf:29bed822261c523d
        mmp_delay = 0
        mmp_valid = 0
        checkpoint_txg = 0
        labels = 0 1 2 3
    Uberblock[29]
        version = 5000
        txg = 15493437
        bp = DVA[0]=<0:163008f7000:1000> DVA[1]=<0:63094fb000:1000> DVA[2]=<0:237c9bd4000:1000> [L0 DMU objset] fletcher4 uncompressed unencrypted LE contiguous unique triple size=1000L/1000P birth=15493437L/15493437P fill=2677 cksum=0000000319e19c98:00000c0216aa700a:0017467fcef025d0:1e1c3e4b925aa050
        mmp_delay = 0
        mmp_valid = 0
        checkpoint_txg = 0
        labels = 0 1 2 3
    Uberblock[30]
        version = 5000
        txg = 15493438
        bp = DVA[0]=<0:16300915000:1000> DVA[1]=<0:6309518000:1000> DVA[2]=<0:237a1b55000:1000> [L0 DMU objset] fletcher4 uncompressed unencrypted LE contiguous unique triple size=1000L/1000P birth=15493438L/15493438P fill=2676 cksum=0000000376f6cf87:00000d630ac08294:0019e4497f6990ad:216c618b5a723e31
        mmp_delay = 0
        mmp_valid = 0
        checkpoint_txg = 0
        labels = 0 1 2 3
    Uberblock[31]
        version = 5000
        txg = 15493439
        bp = DVA[0]=<0:16300948000:1000> DVA[1]=<0:6309552000:1000> DVA[2]=<0:237bf84e000:1000> [L0 DMU objset] fletcher4 uncompressed unencrypted LE contiguous unique triple size=1000L/1000P birth=15493439L/15493439P fill=2677 cksum=00000003ee712f9b:00000f2dc4666278:001d55cb3f249412:25d6d0f0ed8987a2
        mmp_delay = 0
        mmp_valid = 0
        checkpoint_txg = 0
        labels = 0 1 2 3
You’ve got a lot of overlapping timestamps on your uberblocks:
timestamp = 1759868137 UTC = Tue Oct 7 22:15:37 2025 | x137
timestamp = 1759868140 UTC = Tue Oct 7 22:15:40 2025 | x140
timestamp = 1759868142 UTC = Tue Oct 7 22:15:42 2025 | x142
timestamp = 1759868133 UTC = Tue Oct 7 22:15:33 2025 | x133
timestamp = 1759868134 UTC = Tue Oct 7 22:15:34 2025 | x134
timestamp = 1759868136 UTC = Tue Oct 7 22:15:36 2025 | x136
This doesn’t in itself mean guaranteed that the pool is in trouble, but that’s an awful lot of closely-packed overlapping times for ZFS to have to figure out which one is correct.
