I have installed the Docker UrBackup container. For the most part it works really well at backing up a bunch of Windows hosts on the same subnet as our TrueNAS box.
One of the Windows hosts is giving me a lot of trouble. I was advised in the UrBackup forums to launch the UrBackup container with a run -v debug initialization. How do I do that with this container?
Would it go into this section of where I edit the Application Info:
Since truenas apps use docker compose under the hood and not a normal docker run command you’d propably have to set the loglevel via environment variable.
I don’t use urbackup but i found an environment variable in a urbackup forum post
