How to reset my True nas
Hello is there a way for me to wipe my nas system clean data and all and start over. Thank you
Just install it again? Overwrite the boot disk?
Thank you for the fast reply, I tried that each time I do I see my pools as there were before. I made a mistake and imported my pools and I keep seeing my pools as imported
Will I be able to use the same disk I already have in my system?
You want to wipe your storage pools too, not just the boot-pool?
That is correct I want to start fresh, I have been messing around with my system and I feel it needs a clean start
When you export your pool, there’s an option to also wipe the disks.
So I just choose to wipe them? can I wipe all of the disk at one time? and will I be able to use those same disk.
And will the disk be good to go with the full disk space
Thank you
If you choose the “destroy my data” option when exporting the pool, it will wipe all disks of the former pool.
Thank you I don’t see that option, destroy my data I will give it a shot I will have to find that option
I think I found that option that says erase… Thank you
