Problem/Justification
Users need a GUI supported way to import a ZFS pool as “read-only”. This is needed for data verification, external backup checks, emergencies, and other reasons. (It can also be combined with the other feature request, which I did not write yet, to rewind a pool to a checkpoint in a read-only state.)
Impact
Without relying on the command-line or confusing the middleware and other services, a TrueNAS user can import a pool in read-only state. TrueNAS can then mount the datasets as “read-only”, which implies any SMB shares will be in a read-only access.
Users can verify stored files on datasets and snapshots, do emergency file retrieval, or confirm that their cold-storage backups are in working order, without putting the pool into a writable state. These verification can be done in the command-line or over SMB (without write access).
User Story
Browse through the forums. There are many instances where a user needs to (or is told to) import the pool as read-only. They must drop into the command-line via SSH, and might forget to include the -R /mnt
parameter. It could possibly even confuse the middleware and other services.
A first-class “import read-only” feature would work with the middleware and do extra checks in the background.
I have reached the lowest point in my life. I spent all my votes in a craze of power that I no longer have any votes for my own requests.
I guess it’s time to start soliciting for unused votes from other users on this forum. Does anyone accept bitcoin?
I just thought you were forgetful in your voting.
Are there any items you should ‘unvote’?
On fence about voting. A yes vote for Scale but no chance of Core getting it. So sad.
Pretty much implied with every feature request.
You had me at “mounting read-only”.
I like this idea as the forum has been dealing with a lot of ZFS issues in recent past. I also like the “Rewind a Pool” idea. I have no idea how it works, mainly because I have not paid attention to it, but it is a recovery tool.
And now I have 4 votes left.
There have been 10 Feature Requests Approved out of 145 requests.
I think it is time to set everyone back to +10 votes otherwise the people who work these forums the most will not be able to vote for something that could be really good.
I expect at least 5 BTC for my services!
If that one is written, I’d definitely want to see it proposed exclusively as a read-only option through the webUI. Rewinding a pool using any of the special -FXT
parameters inherently involves some lost data (whatever was in the newer transactions) so requiring it to be a very deliberate action (such as providing the command to be entered into a shell) makes sense.
