hi i have tried reinstalling jellyfin app because i cannot find my videos, music and movies
when i login to jellyfin app i used the default for everything except i added additional storage
as in this picture below
can someone please tell me what I’m doing wrong
Product:Default string
motherboard cwwk q670 nas
Model:Intel(R) Pentium(R) Gold 8505
Memory:31 GiB
2 ORICO 128gb sata ssd bootpool
8 hdd
2 seagate exos 8gb pool mediapool
2- maxdigital 6tb pool md6Storage
2-seagate ironwolf 6tb pool Storage1
2 WD red 4tb pool containers_apps
floz
December 10, 2025, 3:46am
When you attempt to add libraries in Jellyfin what do you see? Can you see the mount point?
(Dashboard > Libraries > Libraries > add library > folders)
Also you could the shell button:
(just an example from my portinaer instance)
And with that check the container’s file system (e.g.: ls -l /media/movies) to see if the folder is accessible and if the permissions make sense.
floz
December 10, 2025, 8:51am
4
You can also confirm what is mounted and where with the folder button next to shell. A piccy of that would help if you can’t see the mount point when adding a library.
