Every time you update an app truenas keeps the old docker image, so you don’t have to download the old image again in case you have to roll back to an older version. But truenas doesn’t automatically delete older images if you keep updating and using newer versions. This can lead to quiet big wasted space. The managing container images let’s you delete old unused app images to free up space. It’s basically the docker prune command… It only let’s you delete old unused images. The images currently in use are not deleted.
I actually don’t know where the images are stored. It is somewhere on the pool you selected for apps, but i don’t know if its in the .ix-apps dataset. I only use 3 apps directly on truenas, the other 29 run inside a lxc
In 99% i don’t need the documentation, give me a compose example and some time to tinker (which i really like to do) and i can get things running. I only consult the docs if a container need some weird unknown environment variables to run
Docs feedback from the widget on the docs hub is collected by Jira and turned into a docs ticket to be worked. We look at all of it and do usually make changes based on the feedback, especially when the ticket points to specific issues that need addressing.
