mDNS: if enabled then set nsswitch.conf to also use mDNS for host resolution
Problem/Justification
When mDNS is enabled, clients can use mDNS to reach TrueNAS but TrueNAS cannot use mDNS to access LAN resources. /etc/nsswitch.conf hosts entry does not include mDNS.
Impact
Cannot access LAN resources from TrueNAS using mDNS.
User Story
When mDNS is enabled, also reconfigure /etc/nsswitch.conf to enable mDNS resolution. This is a minimal mDNS configuration. I’m not sure there is a reason to not do this much automatically when mDNS is enabled, but it could be behind a tick box near DNS settings.
System has IPv6 configured on any interface:
hosts: files mdns_minimal [NOTFOUND=return] dns
System is IPv4 only:
hosts: files mdns4_minimal [NOTFOUND=return] dns
This allows mDNS to only resolve:
  • .local which is defined to be mDNS
  • link-local addresses like 169.254 and ff80::
Given TrueNAS is targeting primarily enterprises, this configuration will avoid security or policy concerns from allowing mDNS to resolve other domains/IP addresses. non-.local domains and non-link-local addresses are resolved by the enterprise DNS.
In a home environment it would be desirable to also allow fallback to mDNS via a tick box setting when mDNS is enabled (disabled by default):
hosts: files mdns_minimal [NOTFOUND=return] dns mdns
hosts: files mdns4_minimal [NOTFOUND=return] dns mdns4
This will then also allow resolution of RFC1918 and public addresses e.g. assigned from ISP via DHCPv6 prefix delegation used in the local LAN if DNS fails.
