Mellanox Connect3X poor single stream performance
Hi there,
I’ve just upgraded my newly built TN scale server with a used 10G Mellanox Connect3X card.
The main purpose was to saturate two 2.5G hosts.
Sending and receiving over smb works fine and I get about 280 Mib/s.
When using a single datastream (-P 1) with iperf or rsync (via cifs mount) the server unfortunately only sends at 100-140 mib/s.
Sending to the server with iperf3 gives also the full bandwidth possible.
Any idea how to start debugging this or any general advice?
Thanks in advance!
My Hardware:
SuperMicro X11SSL-F with a XeonCPU E3-1230 v6 @ 3.50GHz (8C)
$ lspci |grep -i mellanox
01:00.0 Ethernet controller: Mellanox Technologies MT27500 Family [ConnectX-3]
iperf3 results:
TN sending:
iperf3 -c 192.168.0.13 -f M   -P 1 -R
Connecting to host 192.168.0.13, port 5201
Reverse mode, remote host 192.168.0.13 is sending
[  6] local 172.22.86.169 port 37958 connected to 192.168.0.13 port 5201
[ ID] Interval           Transfer     Bitrate
[  6]   0.00-1.00   sec   123 MBytes   123 MBytes/sec
[  6]   1.00-2.00   sec   139 MBytes   139 MBytes/sec
[  6]   2.00-3.00   sec   123 MBytes   123 MBytes/sec
[  6]   3.00-4.00   sec   126 MBytes   126 MBytes/sec
[  6]   4.00-5.00   sec   138 MBytes   138 MBytes/sec
[  6]   5.00-6.00   sec   102 MBytes   102 MBytes/sec
[  6]   6.00-7.00   sec   110 MBytes   109 MBytes/sec
[  6]   7.00-8.00   sec   109 MBytes   109 MBytes/sec
[  6]   8.00-9.00   sec   126 MBytes   126 MBytes/sec
[  6]   9.00-10.00  sec   107 MBytes   107 MBytes/sec
[ ID] Interval           Transfer     Bitrate         Retr
[  6]   0.00-10.00  sec  1.18 GBytes   121 MBytes/sec  1590             sender
[  6]   0.00-10.00  sec  1.17 GBytes   120 MBytes/sec                  receiver
iperf Done.
Client sending:
[  6] local 172.22.86.169 port 52914 connected to 192.168.0.13 port 5201
[ ID] Interval           Transfer     Bitrate         Retr  Cwnd
[  6]   0.00-1.00   sec   284 MBytes   284 MBytes/sec    0   3.37 MBytes
[  6]   1.00-2.00   sec   280 MBytes   281 MBytes/sec    0   3.37 MBytes
[  6]   2.00-3.00   sec   280 MBytes   280 MBytes/sec    0   3.37 MBytes
[  6]   3.00-4.00   sec   281 MBytes   281 MBytes/sec    0   3.37 MBytes
[  6]   4.00-5.00   sec   280 MBytes   280 MBytes/sec    0   3.37 MBytes
[  6]   5.00-6.00   sec   281 MBytes   281 MBytes/sec    0   3.81 MBytes
[  6]   6.00-7.00   sec   281 MBytes   281 MBytes/sec    0   3.81 MBytes
[  6]   7.00-8.00   sec   281 MBytes   281 MBytes/sec    0   3.81 MBytes
[  6]   8.00-9.00   sec   280 MBytes   280 MBytes/sec    0   3.81 MBytes
[  6]   9.00-10.00  sec   280 MBytes   280 MBytes/sec    0   3.81 MBytes
[  6]   0.00-10.00  sec  2.74 GBytes   281 MBytes/sec    0             sender
[  6]   0.00-10.01  sec  2.74 GBytes   281 MBytes/sec                  receiver
iperf Done.
The client side runs Windows? Linux? The client also uses a ConnectX-3? I’m a bit confused…
The TrueNAS server is connected via a DAC from the ConnectX card to a Ubiquti 8 port 2.5G switch with a 10G uplink.
iperf testing is done from a Windows host (via WSL) and a Linux host, both with 2.5G NICs.
Windows to Linux and vice versa works with the full bandwidth
