Memory usage
I’m currently running 25.10.0.1 - Goldeye, I have 124.9 GiB DDR5 ECC memory. It’s currently showing the following:
Free: 7.0 GiB
ZFS Cache: 101.7 GiB
Services: 16.3 GiB
I have 8 different Applications running, and 5 VM’s (3 different Ubuntu Servers), 4 different shares via SMB.
CPU is running very low, 5 - 7% most times, most network traffic is through a 10G connection, with admin through a 1G connection.
Everything is running smoothly without issues, just more curious why the ZFS Cache is sucking up most available memory? Before moving over to 25.10.0.1, I had more free memory. I’ve had TrueNAS running on the machine for one year now. I built it in November last year.
Here’s what my NAS is: a bit overkill, but for home, I kinda like to tinker and mess about.
The board is ASRockRack B650D4U-2L2T/BCM, with 128 GiB ECC DDR5 memoryCPU: AMD Ryzen 7 7700X 8-Core Processor (I’m thinking of changing to one of the Epyc CPUs later on)
I have this all stuffed into a Sliger CX3702 NAS case, 5, 3.5 drives, 7, 2.5 SSDs, and one NVMe drive
For zfs free ram is wasted ram. If another process or service needs ram it will shrink down the arc automatically
Edit:
And in the past, there was a 50% limit on arc ( an older zfs on Linux limitation) which got removed and now arc is close to the way it was with Truenas core
Thank you LarsR, I’ve only been doing this for the past year. I’ve very happy with TrueNAS, but like everything, there’s a learning curve involved
Your explanation makes sense, again thanks for the response!
Here’s a brief look at what I have, it’s fairly basic for a home server
