I would like to use midclt to create nagios health checks.
Midclt works fine on the server but not remotely
http → https redirect is enabled, If disabled I have the same error only the ValueError changes to “scheme http is invalid”
midclt -U nagios -P test --uri ws://10.10.10.10/websocket call system.info
Websocket client error: ValueError('scheme https is invalid')
File "/home/nagios/truenas_api_client/truenas_api_client/bin/midclt", line 33, in <module>
sys.exit(load_entry_point('truenas-api-client==0.0.0', 'console_scripts', 'midclt')())
File "/home/nagios/truenas_api_client/truenas_api_client/lib64/python3.11/site-packages/truenas_api_client/__init__.py", line 895, in main
with Client(uri=args.uri) as c:
File "/home/nagios/truenas_api_client/truenas_api_client/lib64/python3.11/site-packages/truenas_api_client/__init__.py", line 93, in __init__
self.__client = client_class(uri, reserved_ports, py_exceptions, log_py_exceptions, call_timeout, verify_ssl)
File "/home/nagios/truenas_api_client/truenas_api_client/lib64/python3.11/site-packages/truenas_api_client/legacy.py", line 230, in __init__
raise ClientException(self._connection_error)
truenas_api_client.exc.ClientException: WebSocket connection closed with code=None, reason=None
