Yes! Just mentioned, you right thanks!
It is mATX but yes, not enough ports.
Your selection is solid. Ither than the RAM issue as @Farout mentioned.
Also check local ads. I am sure there is a local Italian market website. You can find cheaper stuff there with some patience.
Big issue now is that udimm ecc ram have CRAZY prices and few options where to buy… a lot of options instead for rdimm…
It would be much better a motherboard that accept RDIMM DDRs…moreover it would be better for ecc error correction and stability…
I thought you have the RAM already. Or am I mistaken? How much RAM do you need?
What is your use case for the NAS? Just a file server or something else?
I have sodimm 64gb ECC Udimm…need physical sodimm to dimm adapter…
But…
At the end I bought everything!
These ram, 184 euro:
This mobo, 206 euro:
ASRock Rack E3C246D4U2-2T LGA1151 8xSATA Dual DDR4 mATX 10GbE supporto Server NA
This CPU, 49 euro:
Intel Xeon E-2176G SR3WS processore CPU decktop 6 core 3,7 GHz Turbo FCLGA1151
Let’s wait everything to arrive….in the meantime I send back everything, I just keep the Jonsbo n6 case…
about the PSU: 650W should be more than enough no?
Should - but how many disks? Usually 650W only includes 12v, but HDD/SSD also include 3.3 & 5v. Very rare, but it can in theory be an issue.
Realistically, any reasonable 650w PSU should be enough for ~8 HDDs without doing any math.
https://seasonic.com/focus-plus-platinum/
12v 2 amps startup - 16 amps startup on 12v… more than in spec, even with 20 amps on 5v, I think you’re good with that PSU ![]()
Is that still the plan?
The Lexar 790NM is an NVMe SSD but the E3C246D4U2-2T you say you bought has a SATA-only M.2-slot.
Also, keep in mind that on that motherboard the M.2 slot is shared with SATA port #0, which means that using the M.2 means you can’t use more than 7 of the ordinary SATA ports. Did you get an HBA as well or are you going to do some USB-shenanigans for your boot device?
Edit: I was mistaken.
Edit
No. Is not like that.
I’ve just read the manual and if you connect a pci express m.2 ssd, the sata bus stays free for the sata0 hdd.
You lose one sata hdd connection only if you connect a sata m.2 ssd device, if you use a pci express one no problem.
Right, which lines up with what I said.
You haven’t mentioned ultimately buying any PCIe card so I asked you what your plan related to that was.
No, I don’t need any additional card.
The Mobo DO support m.2 pci express ssd, without losing any sata port.
It supports PCIE3.0 x4 or sata for m.2
NO.
This is the usual combination of x4 PCIe lanes (from chipset) plus one SATA lane, shared with a SATA port. With a SATA M.2, one SATA port is disabled. With a NVMe M.2, one gets the full 8 SATA ports.
Just get something smaller as 2 TB just for boot is needless overkill.
I looked and looked at this yesterday and did not spot the line that so clearly says:
M.2 slot - (2230/2242/2260/2280, Supports PCIE3.0(X4)/SATA3)
With that detail things change.
You are all quite right.
Thanks you everyone for the suggestions.
At the end I opted for a Corsair SF750 as psu (80+ platinum) and I’m evaluating and AIO 240 for cpu heatsink
IMO AIOs are not suitable for a 24/7 operation.
In such a case I was thinking of a thermalright AXP 120 x67
Whatever CPU aircooler fits in the case… By current standards, LGA1151-2 CPUs are not that hot or difficult to cool.
