Need help migrating k3s to docker (24.04 to 24.10)
All of my docker containers migrate over but some seem to have some glitches which I haven’t dived to far into yet, but my biggest one is nextcloud.
I previously had a mount location set up mapping “old-nc-www” without a leading slash, and the migration script barks about this. So I deleted the install, deleted the ix-apps dataset, and removed the old-nc-www from my host path volumes and tried the upgrade again. It fails with the exact same error. I have no idea where it’s getting this mount location from if it’s removed from the config Is there somewhere else I should look? K3S makes me have a headache with all the automatically generated kubes and I have no idea where to find anything on here to check for manual data somewhere on the filesystem.
