Need support regarding SMB access issue in TrueNAS SCALE.
We are facing an issue where users are unable to access SMB shares from Windows systems. The error shown is “Windows cannot access \IP\share – permission denied”.
Environment:
  • TrueNAS SCALE (Community Edition)
  • SMB shares configured on datasets under MainPool
  • Multiple datasets (e.g., MSPOWER, MD, Accounts, etc.)
Issue:
  • While applying ACL permissions (NFSv4), we receive errors like:
    “[EPERM] Filesystem permissions on path /mnt/MainPool prevent access for group ‘root’ or user ‘Admin’”
  • It indicates missing execute (traverse) permission on /mnt/MainPool
  • Unable to modify permissions on MainPool (root dataset restriction)
  • chmod is also not permitted
What we tried:
  • Set ACL using presets (NFS4_OPEN)
  • Enabled recursive and child dataset options
  • Restarted SMB service
  • Cleared Windows credentials
Current blocker:
  • Cannot propagate ACL due to parent dataset restriction
  • Users unable to access shares across systems
Request:
  • What is the recommended approach to handle SMB ACL when root dataset restricts traversal?
  • Should we restructure datasets (create a new parent dataset for SMB)?
  • Best practice to avoid EPERM in this scenario?
Any guidance would be very helpful.
Thanks in advance.
Are these Datasets or Folders on the MainPool. The MainPool can not be shared but children datasets can be shared.
