NextCloud plugin not installing
When attempting to install the NextCloud plugin, it fails about half way through with a message basically saying it couldn’t find the PKG at a particular URL. So I followed the URL and it didn’t exist. At that point I went to the URL’s base web address and it did exist and had similar directories, but they were newer than the one the installation was pointing at.
My assumption is this URL to the PKG required to install NextCloud needs to be updated.
What software version are you using 13.??
For deployments with applications we recommend migrating to SCALE 24.10.2
