Nextcloud upgrade failes, and rollback also
I have a problem, when upgrade NextCloud App. Many times the upgrades failes and I need to do a rollback.
But this time, i can’t do rollback with the following error:
I don’t know what to do, because I cant start the app. And can’t find in any config file how to change the status. (I hade the same issue when it said maintanance=true, that time it solved by changeing the maintanance=false)
Do any one have any suggestion what to do?
Here are the error:
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 515, in run
await self.future
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 562, in __run_body
rv = await self.middleware.run_in_thread(self.method, *args)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 599, in run_in_thread
return await self.run_in_executor(io_thread_pool_executor, method, *args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 596, in run_in_executor
File “/usr/lib/python3.11/concurrent/futures/thread.py”, line 58, in run
File “/usr/lib/python3/dist-packages/middlewared/api/base/decorator.py”, line 96, in wrapped
result = func(*args)
File “/usr/lib/python3/dist-packages/middlewared/plugins/apps/rollback.py”, line 41, in rollback
verrors.check()
File “/usr/lib/python3/dist-packages/middlewared/service_exception.py”, line 72, in check
raise self
middlewared.service_exception.ValidationErrors: [EINVAL] app_name: App must not be in stopped state to rollback
