NFS sessions page not working with NFSv4 and IPv6?
Not sure if this is the correct forum to report errors, but I didn’t find anything else.
Is there a bug on the nfs sessions page when having NFSv4 IPv6 clients? I get the error “Can not retrieve response”
I’m using Dragonfish-24.04.2.2
Here is middlewared.log:
[2024/09/30 07:26:58] (WARNING) application.call_method():234 - Exception while calling nfs.get_nfs4_clients(*[])
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 198, in call_method
    result = await self.middleware.call_with_audit(message['method'], serviceobj, methodobj, params, self)
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1466, in call_with_audit
    result = await self._call(method, serviceobj, methodobj, params, app=app,
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1428, in _call
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1321, in run_in_executor
  File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run
  File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 191, in nf
    return func(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 53, in nf
    res = f(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/nfs_/status.py", line 155, in get_nfs4_clients
    "info": self.get_nfs4_client_info(client),
  File "/usr/lib/python3/dist-packages/middlewared/plugins/nfs_/status.py", line 54, in get_nfs4_client_info
    info = yaml.safe_load(f.read())
  File "/usr/lib/python3/dist-packages/yaml/__init__.py", line 125, in safe_load
    return load(stream, SafeLoader)
  File "/usr/lib/python3/dist-packages/yaml/__init__.py", line 81, in load
    return loader.get_single_data()
  File "/usr/lib/python3/dist-packages/yaml/constructor.py", line 49, in get_single_data
    node = self.get_single_node()
  File "/usr/lib/python3/dist-packages/yaml/composer.py", line 36, in get_single_node
    document = self.compose_document()
  File "/usr/lib/python3/dist-packages/yaml/composer.py", line 55, in compose_document
    node = self.compose_node(None, None)
  File "/usr/lib/python3/dist-packages/yaml/composer.py", line 84, in compose_node
    node = self.compose_mapping_node(anchor)
  File "/usr/lib/python3/dist-packages/yaml/composer.py", line 127, in compose_mapping_node
    while not self.check_event(MappingEndEvent):
  File "/usr/lib/python3/dist-packages/yaml/parser.py", line 98, in check_event
    self.current_event = self.state()
  File "/usr/lib/python3/dist-packages/yaml/parser.py", line 438, in parse_block_mapping_key
    raise ParserError("while parsing a block mapping", self.marks[-1],
yaml.parser.ParserError: while parsing a block mapping
  in "<unicode string>", line 1, column 1:
    clientid: 0xd4c0347e66fab279
expected <block end>, but found '<scalar>'
  in "<unicode string>", line 11, column 43:
     ... ddress: [2c00:b00b:babe:a04::23]:0
Thanks!!
It’s an issue with yaml being generated by the kernel. We’ve fixed here: Add quotes around 'callback address' field. · truenas/linux@5c011ad · GitHub for 24.10.
