System: TrueNAS SCALE 25.10.7 (Goldeye), clean install, migrated pools (ZFS, NFSv4 ACL type) from a TrueNAS CORE 13.3 system.
Setup:
- Dataset
tank/photo, NFSv4 ACL granting Read to a named group (tank_photo_ro)
- NFS share on this dataset with
mapall_user set to a local user (pix), whose only group membership is tank_photo_ro
- This exact configuration worked correctly for years on TrueNAS CORE
Symptom:
Mounting this export on any NFS client (tested: Debian, CoreELEC) results in Permission denied when listing the mounted directory. Tested and ruled out:
- NFSv3, NFSv4.1, NFSv4.2 → same failure on all three
- “Manage Groups Server-side” option → enabled, no change
- Adding
mapall_group alongside mapall_user → no change, access still denied
- NFSv4 DNS Domain mismatch → ruled out since NFSv3 (no idmapping involved) fails identically
- Local access as the mapped user (
sudo -u pix ls /mnt/tank/photo) → succeeds without issue
Working workaround:
Replacing or adding the group-based ACE with a named-user ACE (User - pix, Read) on the dataset resolves the issue immediately → same effective permission level, but matched by UID directly instead of group membership.
Conclusion: this points to the “unix token” built for a squashed (mapall_user) NFS connection not correctly carrying the mapped user’s supplementary group memberships during ACL evaluation, even though id <user> reports them correctly and Manage Groups Server-side is enabled. Group-based ACL matching appears to only work reliably for non-squashed (real client identity) NFS connections.
Is this a known/reported issue?
yeah ive hit this on SCALE after a CORE migrate. mapall_user on linux nfsd can skip the supplementary groups when it builds the token for the nfs4 acl check, even when id pix looks fine.
stuff that helped me:
-usermod -g tank_photo_ro pix so the group is primary, not only supplementary
-nfs4_getfacl /mnt/tank/photo and confirm the group ace survived the migrate
-keep the named-user ACE for pix on the squash path (what u already found works)
-Services → NFS → double check Manage Groups Server-side is still on after the clean goldeye install
id file a bug on the mapall supplementary group token. CORE behaved different here for years.
Thanks for confirming. One correction on my end, in my case the group was already primary from the start (id pix → gid=1047(tank_photo_ro)), in CORE then in SCALE, not supplementary, and it still failed. So this doesn’t seem limited to supplementary group resolution; the primary group isn’t making it into the token either on the mapall_user/squash path. Might point to something more fundamental in how the token gets built for squashed NFS connections, not just a supplementary-groups oversight.
Bug filed:
I have checked the “Manage Groups Server-side” option before posting on the forum, but it didn’t change anything.
truenas% sudo nfs4_getfacl /mnt/tank/photo
Operation to request attribute not supported: /mnt/tank/photo
truenas% sudo nfs4xdr_getfacl /mnt/tank/photo
File: /mnt/tank/photo
owner: 10XX
group: 10YY
mode: 0o40770
trivial_acl: false
ACL flags: none
owner@:rwxpDdaARWcCos:fd-----:allow
group@:rwxpDdaARWc--s:fd-----:allow
group:tank_photo_ro:r-x---a-R-c---:fd-----:allow
user:pix:r-x---a-R-c---:fd-----:allow
Here, the only change I had to do to make it work, was to add the user pix:
yeah if primary gid was already tank_photo_ro and mapall still denies, that points at the squash token on SCALE nfsd for me.
id try next:
-export once w/ mapall_user empty, mount as the real user that owns the ACE, confirm ls works
-then put mapall_user=pix back and also set mapall_group / anonymous GID to tank_photo_ro if the share UI exposes it
-nfs4_getfacl /mnt/tank/photo and paste the group ACE line
worth a jira w/ SCALE 25.10.7 + that primary gid was already correct and list still Permission denied under mapall.
