Not showing text labels
Thank you for the add, first post.
Text is not showing on the labels or flyouts no matter which version i install
USED to be fine
Hardware is still the same
Windows 10 ver 22H2 build 19045.4529
Attached is a screenshot
Hard refresh the page, or dump your web browsers cache.
thank you, i will try that
That worked, thank you.
very much appreciated
Was using firefox browser
Check the solution box next to the post :wink:
