Paperless-ngx backup and restore process
Hi Fabian,
you are correct. the workaround requires dedicated datasets. then one of these datasets can be “misused” for the export path as well since the container has access to it.
let me know if that helps. btw: you can simply create a seconda instance of paperless create new datasets and try to restore from your first instance. good excersise :wink:
