So I just built a new server so I can move my files from old unit that is dying.
Dell Precision 5820 Tower
But I installed everything on a M2 and when I log in there is a phantom drive.
name- sdc, Serial 28203008282014000, Disk Size 0 B, Disk Type SSD, Model SD_MMC_CRW
But when I open it there is only 1 drive my m2 for boot. I tore it apart and can not find any other drives.
Would anyone have any ideas why it is doing that?
You can try running lsblk -bo NAME,LABEL,MAJ:MIN,TRAN,ROTA,ZONED,VENDOR,MODEL,SERIAL,PARTUUID,START,SIZE,PARTTYPENAME and seeing what it reports. Does your system have a MMC onboard for booting. the Model is a clue, it may
Yes, I have to agree with @SmallBarky, this does appear to be an embedded SD/MMC boot device. With it being “Disk Size 0 B”, I would guess it is not populated.
For practical purposes, you can probably just ignore it. But, if you are interested, you can see if their is a SD-Card slot, or a MMC header on the system board.
Note that some computers have optional features, and yours might not have the slot or header installed. Yet the device controller would still be present because it was listed by the software.
So I assume it is something in USB slot. I will look again or track it down in bios maybe. Or like someone suggested just ignore it But thank you for the help.
