Pool is not healthy
I was taking apart my NAS for maintenance. After reassembling it, one of my pools came back with 4 Checksum Errors on one drive.
I ran a Scrub, and it finished with 0 new errors, but the pool is still showing a Red/Unhealthy status because of those previous 4 errors.
I suspect I had a loose power connection during the first boot. How do I clear these old errors to get the pool back to a healthy green state?
There may be a way to do it from the GUI, but from the Linux shell;
sudo zpool clear FlashStorage01
In general, checksum errors are data cable problems. Though it could have been loose power cable.
thank you that did it.
