pool size not increasing
so here is the story. I have 3 drives in raidz1, 14.41 Tib at 84% capacity, I buy a 4th drive, put it in expand pool… drive was DOA would not expand pool past 25%, RMA the drive, get new drive, put in, detected correctly, resilver is done all is OK. however pool size is not increasing. did a pool expand in Sclate to “use all available space” nothing is increasing.
So I have a 4 drive pool the size of a 3 drive pool that will not expand it’s size. It could be because of the original failed pool expansion but I assumed there would be a workaround to expand it., Any help on doing this without wiping the pool? thanks
Check the size in the CLI and not the GUI. Search the forums for RAID-Zx-expansion . it sounds like a known issue.
