Noob question here I do have a script to control some FANs via IPMI and it is working fine, here is the code:
#!/bin/sh
echo “IPMI - FAN Setting Start”
Set FAN mode to “full”
ipmitool raw 0x30 0x45 0x01 0x01
sleep 1.25
Set FAN speed in “system” zone to 45%
ipmitool raw 0x30 0x70 0x66 0x01 0x00 0x2D
sleep 1.25
Set FAN speed in “peripheral” zone to 70%
ipmitool raw 0x30 0x70 0x66 0x01 0x01 0x46
sleep 2
Print-out the current FAN speed
echo “IPMI - Current FAN Speed”
ipmitool sdr | grep -e FAN1 -e FANA
The only thing that I dont see is the print of those messages in DMESG…
Tried to look anywhere at /VAR/LOG and nothing is there
Used this command to try to find it
grep -rnw ‘/var/’ -e ‘FAN’ and nothing related to the ECHO messages.
im not a bash expert but i’m pretty sure that when you use
you are effectively not logging anything, but only serving those data in the standard output.
Probably just adding something like >> "/mnt/*****" 2>&1 (obv replacing the path location with something real) on each row do the job.
echo “IPMI - Current FAN Speed” >> "/mnt/*****" 2>&1
ipmitool sdr | grep -e FAN1 -e FANA >> "/mnt/*****" 2>&1
IMHO better if you define a var on top of the script like LogDir="/mnt/*****" and then use it instead of the hard path on each row
echo “IPMI - Current FAN Speed” >> "$LogDir" 2>&1
ipmitool sdr | grep -e FAN1 -e FANA >> "$LogDir" 2>&1
in case of need, change first line instead of n lines (and if script grows, can be a pain)
It has been a while since I used logger to write system log entries. But, if I remember correctly, setting the parameters can allow writing to both /var/log/messages and console.
You should be able to test this in a script, before making it a post init script.
