The other Day i got a warning about two of m’y Drive on pool on radz2 configuration with 6 x 1tb
The disk in question 2 of the six was un warning and one was red
So i done this i put this two disk offline un prévision to switch Them with my 2 other spare one i have
Truenas Sée both disk but the pool have dissapear
But when i look at the storage all disk remaining from the other pool marked as exported bit i cant take IT back to Do my pool again
I try zpool command and Says the zpool command dont work lblskl Sée the map of the other Drive
I’m lost at that point and i didnt expect that also i dont have any backup IT smell shit alot
Found the problem
I’m on radz2 configuration and when i saw that i was having issue with the swap of the hdd
I put 2 Drive off Line from the pool There was my mistake number one second was mot calculated the parity
Witch truenas was like yo Bro what the f… Are you doing
And prevent from loosing IT
I told m’y self why i dont put back thèse 2 Drive inside the NAS and Sée if anything came back to normal indeed
There was my answer
Today i done the same procedure but with one différence
I only swap one Drive to ne sûre to not be strangled with that problem again
