Thanks for your reply.
Before starting this thread, I did experiment with the Web UI’s “Custom User” option – I think this is equivalent to the dockerfile UID/GID settings.
Running as 568:568 seems to make the container pretty unhappy, with whoami complaining before every prompt:
@a492b18ae9b8:/mnt/Music$ pwd
/mnt/Music
whoami: cannot find name for user ID 568
@a492b18ae9b8:/mnt/Music$ whoami
This is quite a nuisance, since beets is a command-line program!
I also see that the placeholder user abc never gets set to its proper UID/GID according to /etc/passwd. It’s still set to 911:911:
@a492b18ae9b8:/mnt/Music$ cat /etc/passwd
root:x:0:0:root:/root:/bin/sh
bin:x:1:1:bin:/bin:/sbin/nologin
daemon:x:2:2:daemon:/sbin:/sbin/nologin
lp:x:4:7:lp:/var/spool/lpd:/sbin/nologin
sync:x:5:0:sync:/sbin:/bin/sync
shutdown:x:6:0:shutdown:/sbin:/sbin/shutdown
halt:x:7:0:halt:/sbin:/sbin/halt
mail:x:8:12:mail:/var/mail:/sbin/nologin
news:x:9:13:news:/usr/lib/news:/sbin/nologin
uucp:x:10:14:uucp:/var/spool/uucppublic:/sbin/nologin
cron:x:16:16:cron:/var/spool/cron:/sbin/nologin
ftp:x:21:21::/var/lib/ftp:/sbin/nologin
sshd:x:22:22:sshd:/dev/null:/sbin/nologin
games:x:35:35:games:/usr/games:/sbin/nologin
ntp:x:123:123:NTP:/var/empty:/sbin/nologin
guest:x:405:1000:guest:/dev/null:/sbin/nologin
nobody:x:65534:65534:nobody:/:/sbin/nologin
klogd:x:100:101:klogd:/dev/null:/sbin/nologin
abc:x:911:1001::/config:/bin/false
But setting up abc’s UID/GID doesn’t matter, since all processes are running under UID 568; none under root or abc:
@a492b18ae9b8:/mnt/Music$ ps aux
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
568 1 0.0 0.0 440 0 ? Ss 22:39 0:00 /package/admin/s6/command/s6-svscan -d4 -- /r
568 21 0.0 0.0 220 0 ? S 22:39 0:00 s6-supervise s6-linux-init-shutdownd
568 24 0.0 0.0 208 0 ? Ss 22:39 0:00 /package/admin/s6-linux-init/command/s6-linux
568 40 0.0 0.0 220 0 ? S 22:39 0:00 s6-supervise svc-beets
568 41 0.0 0.0 220 0 ? S 22:39 0:00 s6-supervise s6rc-oneshot-runner
568 42 0.0 0.0 220 0 ? S 22:39 0:00 s6-supervise svc-cron
568 43 0.0 0.0 220 0 ? S 22:39 0:00 s6-supervise s6rc-fdholder
568 51 0.0 0.0 208 0 ? Ss 22:39 0:00 /package/admin/s6/command/s6-ipcserverd -1 --
568 160 0.0 0.0 2388 1280 ? Ss 22:39 0:00 bash ./run svc-cron
568 161 0.4 0.0 419264 60700 ? Ssl 22:39 0:02 /lsiopy/bin/python3 /lsiopy/bin/beet web
568 179 0.0 0.0 7612 1544 ? S 22:39 0:00 sleep infinity
568 210 0.0 0.0 1724 696 pts/0 Ss 22:39 0:00 sh
568 291 0.0 0.0 2936 1624 pts/0 R+ 22:48 0:00 ps aux
I guess this is all expected behavior. We’re brute-forcing the container to run as 568, which screws up the s6 init system, prevents editing /etc/passwd, etc. LSIO gave us the heads-up about this here: Running Containers As A Non-Root User - LinuxServer.io
Anyway – with this option set, new files are created as 568:568, so this does technically accomplish my goal. But the container seems a little broken this way, and the docs seem to make it clear that PUID/PGID are the intended way to do this.
I should try running this same LSIO image on a non-TrueNAS system; maybe it’s just a bug in their release. But beets-flask has been working perfectly, so I’ve lost my motivation to chase this one down
