Is there any way to repair my TrueNAS-13.0-U5.3 installation? I stupidly deleted the NUT service!
Thank you in advance.
LM
LM
Download a fresh ISO and reinstall. Then upload your saved config file (you do have one, right), and you’re set.
Perhaps better, boot into an earlier boot environment, then update to the latest (I think U6.1 is current, and the end of the line for CORE).
Thank you for your quick response! I had to run off before thanking you. As for the saved config file, let’s hope there is one!
God bless, Dan!
