A few weeks ago I had a disk just up and go missing from my main pool. Since then, I have been attempting to replace it and am running into an issue where 2 disks in a row just don’t show up in Truenas for me to use.
System setup:
TrueNAS - 25.04.2.4
Motherboard - Asrock X370 Killer SLI/ac
CPU - AMD Ryzen 5 1600
Ram - Corsair Vengeance LPX 32GB (2 x 16GB) DDR4 DRAM 3200MHz C16
PSU - Corsair CX 750M
LSI HBA (dmsg output below)
mpt2sas_cm0: LSISAS2308: FWVersion(20.00.07.00), ChipRevision(0x05)
Original disk layout was 4x Exos X16 14TB SATA (ST14000NM005G) in Z2
Attempting to replace the supposedly dead one with an Exos X14 14TB SATA (ST14000NM0258). [Yes, these are all used disks. This is for personal use and new costs are insane just to store my media and personal computer backups.]
I’ve been using sata power pigtails to solve for the 3.3v concern but these just won’t show up no matter what I try.
Here’s my lsblk output
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
loop1 7:1 0 365.3M 1 loop
sda 8:0 0 12.7T 0 disk
└─sda1 8:1 0 12.7T 0 part
sdb 8:16 0 12.7T 0 disk
└─sdb1 8:17 0 12.7T 0 part
sdc 8:32 0 29.8G 0 disk
├─sdc1 8:33 0 1M 0 part
├─sdc2 8:34 0 512M 0 part
└─sdc3 8:35 0 29.3G 0 part
sdd 8:48 0 12.7T 0 disk
└─sdd1 8:49 0 12.7T 0 part
sde 8:64 0 238.5G 0 disk
└─sde1 8:65 0 238.5G 0 part
sdf 8:80 0 238.5G 0 disk
└─sdf1 8:81 0 238.5G 0 part
sdg 8:96 0 29.8G 0 disk
├─sdg1 8:97 0 1M 0 part
├─sdg2 8:98 0 512M 0 part
└─sdg3 8:99 0 29.3G 0 part
The original three 14TB drives show up just fine, but I cannot get the one that (apparently) died or either of the replacements to be recognized when going through the HBA.
Things I’ve tried:
-Using a different cable from the LSI card
-Using a different port on the LSI card
-Excluding the sata power pigtail
-Using a separate sata cable from the PSU
-Unplugging 4 other disks from power in case for some reason my PSU didn’t like the total draw
-Using a SATA data cable directly from the motherboard
When I plug the new disk into a SATA port directly on the motherboard instead, the original doesn’t show up at all. The newest one does show up (see lsblk below - shows up as ‘sbc’) but it cannot be used. When I try to replace and when I try to wipe it, I get ERRNO 5 input/output error - also below.
sdc 8:32 0 12.7T 0 disk
sde 8:64 0 29.8G 0 disk
├─sde1 8:65 0 1M 0 part
├─sde2 8:66 0 512M 0 part
└─sde3 8:67 0 29.3G 0 part
sdg 8:96 0 238.5G 0 disk
└─sdg1 8:97 0 238.5G 0 part
sdh 8:112 0 29.8G 0 disk
├─sdh1 8:113 0 1M 0 part
├─sdh2 8:114 0 512M 0 part
└─sdh3 8:115 0 29.3G 0 part
Error when try to replace and when try to wipe:
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 515, in run
await self.future
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 560, in _run_body
rv = await self.method(*args)
File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 174, in nf
File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 48, in nf
res = await f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/disk/wipe.py", line 143, in wipe
await self.middleware.run_in_thread(self.wipe_impl, job, dev, mode, event)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 627, in run_in_thread
return await self.run_in_executor(io_thread_pool_executor, method, *args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 624, in run_in_executor
File “/usr/lib/python3.11/concurrent/futures/thread.py”, line 58, in run
File "/usr/lib/python3/dist-packages/middlewared/plugins/disk/wipe.py", line 89, in _wipe_impl
os.fsync(f.fileno())
OSError: [Errno 5] Input/output error
smartctl -a on the disk that finally showed up
Device Model: ST14000NM0258
Serial Number: ZHZ69JQ1
LU WWN Device Id: 5 000c50 0c4df5f59
Firmware Version: SS02
User Capacity: 14,000,519,643,136 bytes [14.0 TB]
Sector Size: 512 bytes logical/physical
Rotation Rate: 7200 rpm
Device is: Not in smartctl database 7.3/6028
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.0, 6.0 Gb/s
Local Time is: Tue Jan 13 00:01:34 2026 CST
SMART support is: EnabledRead SMART Data failed: scsi error device not ready
I’m still new to Truenas (and anything non-Windows), so assume I don’t automatically know how to do the specific thing you’re asking me to do.
Thank you for any help you can give me.
