I have a motherboard that reports following data:
00:17.0 SATA controller: Intel Corporation Alder Lake-S PCH SATA Controller [AHCI Mode] (rev 11) (prog-if 01 [AHCI 1.0])
DeviceName: Onboard - SATA
Subsystem: ASUSTeK Computer Inc. Alder Lake-S PCH SATA Controller [AHCI Mode]
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 146, IOMMU group 7
Memory at 84b20000 (32-bit, non-prefetchable) [size=8K]
Memory at 84b23000 (32-bit, non-prefetchable) [size=256]
I/O ports at 4090 [size=8]
I/O ports at 4080 [size=4]
I/O ports at 4060 [size=32]
Memory at 84b22000 (32-bit, non-prefetchable) [size=2K]
Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [70] Power Management version 3
Capabilities: [a8] SATA HBA v1.0
Kernel driver in use: ahci
Kernel modules: ahci
That means that is in the right mode for TrueNas to operate?
I can see drives and their serial numbers and I’m running a full SMART test right now.
truenas_admin@truenas[~]$ sudo smartctl --all /dev/sda
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.6.44-production+truenas] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Western Digital Ultrastar DC HC550
Device Model: WDC WUH721816ALE6L4
Serial Number: 2PJGB4AZ
LU WWN Device Id: 5 000cca 2c1e2b605
Firmware Version: PCGNW870
User Capacity: 16,000,900,661,248 bytes [16.0 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Device is: In smartctl database 7.3/5528
ATA Version is: ACS-4 published, ANSI INCITS 529-2018
SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Tue Dec 24 21:24:52 2024 CET
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x80) Offline data collection activity
was never started.
Self-test execution status: ( 245) Self-test routine in progress...
50% of test remaining.
data collection: ( 101) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: (1976) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000b 100 100 001 Pre-fail Always - 0
2 Throughput_Performance 0x0005 100 100 054 Pre-fail Offline - 0
3 Spin_Up_Time 0x0007 097 097 001 Pre-fail Always - 139
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 2
5 Reallocated_Sector_Ct 0x0033 100 100 001 Pre-fail Always - 0
199 UDMA_CRC_Error_Count 0x000a 100 100 000 Old_age Always - 0
And when I plugged (Hot Plug support seems to work too) an old failing drive I got a warning about failing drive. That means I’m good to go and I can start setting up filesystem and dataset?
