Small error in 25.10 documentation re: AD join/NTP config
I was following the AD join steps at
(can’t add link in post but the doc is under www dot truenas dot com /docs/scale/25.10/scaletutorials/credentials/directoryservices/configadscale/)
… which says that NTP settings are under System → General Settings , but they are under System → Advanced Settings.
Thanks. I’ll get that updated.
In the future you can also use the feedback button on the right side of a docs page to file a ticket directly with the docs team or, for quick changes, even edit the offending sentence yourself with the Edit this Page link at the top right of the article (requires a github account).
