midclt call disk.smart_test LONG ’{serial_lunid}WPV077HZ_50xcccx", “{serial_lunid}WPV077RD_50xcccv”, "{serial_lunid}ZAD02S2L_50xcccv”, “{serial_lunid}ZAD54T3Q_50xcccv”, “{serial_lunid}ZAD54V66_50xcccv”, “{serial_lunid}ZAD7L00Q_50xccccv”]’
Produced the following output:
null
I received the above email alert from my TrueNAS box this morning.
I’ve got that as a cron job running a short test weekly and a long test monthly.
Under 25.10, with the changes in smart reporting, I’m now getting the above output. Should I just ignore the null message, and assume the tests are still being run and reported through my scrutiny instance?
How do I check time stamps in Scrutiny? The “last updated” time it shows is simply when I just restarted the app (having added a Timezone environment variable). My cron job ran at midnight last night.
Hmmm. I can’t find anything anywhere. My drives have been powered on for “2 years” according to scrutiny…not exactly precise information!
I find it surprising that Scrutiny doesn’t show when the SMART data is it displaying so prettily is from. Well, maybe it sort of does. Under details > history, it does give the time it’s reporting against.
But that’s much more regularly than my SHORT and LONG tests, so I don’t think it’s reporting those results.
Perhaps SHORT & LONG tests aren’t needed with Scrutiny?
That isn’t the way SMART works. I believe Scrutiny only “monitors”, I do not think it does any testing. TrueNAS Goldeye “monitors” as well, it just doesn’t show you the data in a GUI, but it emails you and puts notification in the GUI alert section when if detects an error from smartd
