Syncthing Filesystem Watcher Errors
Syncthing has been running great for me but when I mounted the network share in Bazzite and set it as the destination for a Deja Dup backup I started getting this error:
![Filesystem Watcher Errors
For the following folders an error occurred while starting to watch for changes. It will be retried every minute, so the errors might go away soon. If they persist, try to fix the underlying issue and ask for help if you can’t. Support
W:\Sync error while traversing /mnt/SyncThing/W Sync/backups/framework-baz: permission denied|690x189](upload://5XC4QCz9TOgVD9c52UFBPQCFxOT.png)
I tried running chown and chmod but it didn’t fix it.
Anyone have any ideas on how to fix this?
Hmm, something weird happened to that first screenshot in the post and now it won’t let me edit it, but it looks like this:
If the connections are working, then have you checked the “Ignore Permissions” box for the shared file under Edit>Advanced for both Truenas and the client? Also, the Syncthing community forum may be a better help.
I think that was it, thanks!
