Hi All,
Hoping to get some help. I have transmission installed in iocage and it started crashing 2 days ago. Transmission is installed as service and will crash 15 seconds after starting or sometimes 30 seconds. The time appears random, but either way it eventually crashes within a short time of starting. Normally I would go to the logs to find clues, but there’s nothing in the logs so now I’m at a loss of how to solve this problem. For completeness, here’s the logs:
Jul 21 09:00:06 MediaDownloader newsyslog[47973]: logfile turned over due to size>1000K
Jul 28 12:20:29 MediaDownloader openvpn[53999]: [budapest402] Inactivity timeout (--ping-restart), restarting
Jul 28 12:20:29 MediaDownloader openvpn[53999]: SIGUSR1[soft,ping-restart] received, process restarting
Jul 28 12:20:30 MediaDownloader openvpn[53999]: TCP/UDP: Preserving recently used remote address: [AF_INET]86.106.74.126:501
Jul 28 12:20:30 MediaDownloader openvpn[53999]: Attempting to establish TCP connection with [AF_INET]86.106.74.126:501
Jul 28 12:21:34 MediaDownloader openvpn[53999]: TCP connection established with [AF_INET]86.106.74.126:501
Jul 28 12:21:34 MediaDownloader openvpn[53999]: TCPv4_CLIENT link local: (not bound)
Jul 28 12:21:34 MediaDownloader openvpn[53999]: TCPv4_CLIENT link remote: [AF_INET]86.106.74.126:501
Jul 28 12:21:35 MediaDownloader openvpn[53999]: [budapest402] Peer Connection Initiated with [AF_INET]86.106.74.126:501
Jul 28 12:21:35 MediaDownloader openvpn[53999]: Preserving previous TUN/TAP instance: tun4
Jul 28 12:21:35 MediaDownloader openvpn[53999]: Initialization Sequence Completed
Aug 1 18:14:53 MediaDownloader syslogd: kernel boot file is /boot/kernel/kernel
Aug 1 18:14:53 MediaDownloader openvpn[2818]: DEPRECATED OPTION: --cipher set to 'aes-256-cbc' but missing in --data-ciphers (AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305). OpenVPN ignores --cipher for cipher negotiations.
Aug 1 18:14:53 MediaDownloader openvpn[2818]: WARNING: file '/usr/local/etc/openvpn/pass.txt' is group or others accessible
Aug 1 18:14:53 MediaDownloader openvpn[2818]: OpenVPN 2.6.12 amd64-portbld-freebsd13.3 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD]
Aug 1 18:14:53 MediaDownloader openvpn[2818]: library versions: OpenSSL 1.1.1t-freebsd 7 Feb 2023, LZO 2.10
Aug 1 18:14:53 MediaDownloader openvpn[2820]: CRL: loaded 1 CRLs from file -----BEGIN X509 CRL----- REDACTED -----END X509 CRL-----
Aug 1 18:14:53 MediaDownloader openvpn[2820]: TCP/UDP: Preserving recently used remote address: [AF_INET]86.106.74.120:501
Aug 1 18:14:53 MediaDownloader openvpn[2820]: Attempting to establish TCP connection with [AF_INET]86.106.74.120:501
Aug 1 18:14:53 MediaDownloader openvpn[2820]: TCP connection established with [AF_INET]86.106.74.120:501
Aug 1 18:14:53 MediaDownloader openvpn[2820]: TCPv4_CLIENT link local: (not bound)
Aug 1 18:14:53 MediaDownloader openvpn[2820]: TCPv4_CLIENT link remote: [AF_INET]86.106.74.120:501
Aug 1 18:14:53 MediaDownloader openvpn[2820]: WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Aug 1 18:14:54 MediaDownloader openvpn[2820]: [budapest402] Peer Connection Initiated with [AF_INET]86.106.74.120:501
Aug 1 18:14:54 MediaDownloader openvpn[2820]: TUN/TAP device /dev/tun4 opened
Aug 1 18:14:54 MediaDownloader openvpn[2820]: /sbin/ifconfig tun4 10.7.19.20/24 mtu 1500 up
Aug 1 18:14:54 MediaDownloader openvpn[2820]: Initialization Sequence Completed
Aug 4 14:31:18 MediaDownloader openvpn[2820]: [budapest402] Inactivity timeout (--ping-restart), restarting
Aug 4 14:31:18 MediaDownloader openvpn[2820]: SIGUSR1[soft,ping-restart] received, process restarting
Aug 4 14:31:19 MediaDownloader openvpn[2820]: TCP/UDP: Preserving recently used remote address: [AF_INET]86.106.74.120:501
Aug 4 14:31:19 MediaDownloader openvpn[2820]: Attempting to establish TCP connection with [AF_INET]86.106.74.120:501
Aug 4 14:32:23 MediaDownloader openvpn[2820]: TCP connection established with [AF_INET]86.106.74.120:501
Aug 4 14:32:23 MediaDownloader openvpn[2820]: TCPv4_CLIENT link local: (not bound)
Aug 4 14:32:23 MediaDownloader openvpn[2820]: TCPv4_CLIENT link remote: [AF_INET]86.106.74.120:501
Aug 4 14:32:25 MediaDownloader openvpn[2820]: [budapest402] Peer Connection Initiated with [AF_INET]86.106.74.120:501
Aug 4 14:32:25 MediaDownloader openvpn[2820]: Preserving previous TUN/TAP instance: tun4
Aug 4 14:32:25 MediaDownloader openvpn[2820]: Initialization Sequence Completed
Aug 5 03:35:18 MediaDownloader openvpn[2820]: [budapest402] Inactivity timeout (--ping-restart), restarting
Aug 5 03:35:18 MediaDownloader openvpn[2820]: SIGUSR1[soft,ping-restart] received, process restarting
Aug 5 03:35:19 MediaDownloader openvpn[2820]: TCP/UDP: Preserving recently used remote address: [AF_INET]86.106.74.120:501
Aug 5 03:35:19 MediaDownloader openvpn[2820]: Attempting to establish TCP connection with [AF_INET]86.106.74.120:501
Aug 5 03:35:34 MediaDownloader openvpn[2820]: TCP: connect to [AF_INET]86.106.74.120:501 failed: No route to host
Aug 5 03:35:34 MediaDownloader openvpn[2820]: SIGUSR1[connection failed(soft),connection-failed] received, process restarting
Aug 5 03:35:35 MediaDownloader openvpn[2820]: TCP/UDP: Preserving recently used remote address: [AF_INET]217.138.192.218:501
Aug 5 03:35:35 MediaDownloader openvpn[2820]: Attempting to establish TCP connection with [AF_INET]217.138.192.218:501
Aug 5 03:36:50 MediaDownloader openvpn[2820]: TCP: connect to [AF_INET]217.138.192.218:501 failed: Operation timed out
Aug 5 03:36:50 MediaDownloader openvpn[2820]: SIGUSR1[connection failed(soft),connection-failed] received, process restarting
Aug 5 03:36:51 MediaDownloader openvpn[2820]: TCP/UDP: Preserving recently used remote address: [AF_INET]185.94.190.197:501
Aug 5 03:36:51 MediaDownloader openvpn[2820]: Attempting to establish TCP connection with [AF_INET]185.94.190.197:501
Aug 5 03:38:06 MediaDownloader openvpn[2820]: TCP: connect to [AF_INET]185.94.190.197:501 failed: Operation timed out
Aug 5 03:38:06 MediaDownloader openvpn[2820]: SIGUSR1[connection failed(soft),connection-failed] received, process restarting
Aug 5 03:38:07 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 03:38:07 MediaDownloader syslogd: last message repeated 1 times
Aug 5 03:38:07 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 03:38:07 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 03:38:08 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 03:38:08 MediaDownloader syslogd: last message repeated 1 times
Aug 5 03:38:08 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 03:38:08 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 03:38:09 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 03:38:09 MediaDownloader syslogd: last message repeated 1 times
Aug 5 03:38:09 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 03:38:09 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 03:38:10 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 03:38:10 MediaDownloader syslogd: last message repeated 1 times
Aug 5 03:38:10 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 03:38:10 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 03:38:11 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 03:38:11 MediaDownloader syslogd: last message repeated 1 times
Aug 5 03:38:11 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 03:38:11 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 03:38:13 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 03:38:13 MediaDownloader syslogd: last message repeated 1 times
Aug 5 03:38:13 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 03:38:13 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 03:38:17 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 03:38:17 MediaDownloader syslogd: last message repeated 1 times
Aug 5 03:38:17 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 03:38:17 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 03:38:25 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 03:38:25 MediaDownloader syslogd: last message repeated 1 times
Aug 5 03:38:25 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 03:38:25 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 03:38:42 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 03:38:42 MediaDownloader syslogd: last message repeated 1 times
Aug 5 03:38:42 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 03:38:42 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 03:39:14 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 03:39:14 MediaDownloader syslogd: last message repeated 1 times
Aug 5 03:39:14 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 03:39:14 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 03:40:18 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 03:40:18 MediaDownloader syslogd: last message repeated 1 times
Aug 5 03:40:18 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 03:40:18 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 03:42:26 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 03:42:26 MediaDownloader syslogd: last message repeated 1 times
Aug 5 03:42:26 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 03:42:26 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 03:46:42 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 03:46:42 MediaDownloader syslogd: last message repeated 1 times
Aug 5 03:46:42 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 03:46:42 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 03:51:42 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 03:51:42 MediaDownloader syslogd: last message repeated 1 times
Aug 5 03:51:42 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 03:51:42 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 03:56:42 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 03:56:42 MediaDownloader syslogd: last message repeated 1 times
Aug 5 03:56:42 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 03:56:42 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 04:01:42 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 04:01:42 MediaDownloader syslogd: last message repeated 1 times
Aug 5 04:01:42 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 04:01:42 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 04:06:42 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 04:06:42 MediaDownloader syslogd: last message repeated 1 times
Aug 5 04:06:42 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 04:06:42 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 04:11:42 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 04:11:42 MediaDownloader syslogd: last message repeated 1 times
Aug 5 04:11:42 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 04:11:42 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 04:16:42 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 04:16:42 MediaDownloader syslogd: last message repeated 1 times
Aug 5 04:16:42 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 04:16:42 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 04:21:42 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 04:21:42 MediaDownloader syslogd: last message repeated 1 times
Aug 5 04:21:42 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 04:21:42 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 04:26:42 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 04:26:42 MediaDownloader syslogd: last message repeated 1 times
Aug 5 04:26:42 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 04:26:42 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 04:31:42 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 04:31:42 MediaDownloader syslogd: last message repeated 1 times
Aug 5 04:31:42 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 04:31:42 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 04:36:42 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 04:36:42 MediaDownloader syslogd: last message repeated 1 times
Aug 5 04:36:42 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 04:36:42 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 04:41:42 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 04:41:42 MediaDownloader syslogd: last message repeated 1 times
Aug 5 04:41:42 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 04:41:42 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 04:46:42 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 04:46:42 MediaDownloader syslogd: last message repeated 1 times
Aug 5 04:46:42 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 04:46:42 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 04:51:42 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 04:51:42 MediaDownloader syslogd: last message repeated 1 times
Aug 5 04:51:42 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 04:51:42 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 04:56:42 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 04:56:42 MediaDownloader syslogd: last message repeated 1 times
Aug 5 04:56:42 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 04:56:42 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 05:01:42 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 05:01:42 MediaDownloader syslogd: last message repeated 1 times
Aug 5 05:01:42 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 05:01:42 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 05:06:42 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 05:06:42 MediaDownloader syslogd: last message repeated 1 times
Aug 5 05:06:42 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 05:06:42 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 05:11:42 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 05:11:42 MediaDownloader syslogd: last message repeated 1 times
Aug 5 05:11:42 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 05:11:42 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 05:16:42 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 05:16:42 MediaDownloader syslogd: last message repeated 1 times
Aug 5 05:16:42 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 05:16:42 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 05:21:42 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 05:21:42 MediaDownloader syslogd: last message repeated 1 times
Aug 5 05:21:42 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 05:21:42 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 05:26:42 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 05:26:42 MediaDownloader syslogd: last message repeated 1 times
Aug 5 05:26:42 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 05:26:42 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 05:31:42 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 05:31:42 MediaDownloader syslogd: last message repeated 1 times
Aug 5 05:31:42 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 05:31:42 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 05:36:42 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 05:36:42 MediaDownloader syslogd: last message repeated 1 times
Aug 5 05:36:42 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 05:36:42 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 05:41:42 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 05:41:42 MediaDownloader syslogd: last message repeated 1 times
Aug 5 05:41:42 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 05:41:42 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 05:46:42 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 05:46:42 MediaDownloader syslogd: last message repeated 1 times
Aug 5 05:46:42 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 05:46:42 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 05:51:42 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 05:51:42 MediaDownloader syslogd: last message repeated 1 times
Aug 5 05:51:42 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 05:51:42 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 05:56:42 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 05:56:42 MediaDownloader syslogd: last message repeated 1 times
Aug 5 05:56:42 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 05:56:42 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 06:01:42 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 06:01:42 MediaDownloader syslogd: last message repeated 1 times
Aug 5 06:01:42 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 06:01:42 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 06:06:42 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 06:06:42 MediaDownloader syslogd: last message repeated 1 times
Aug 5 06:06:42 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 06:06:42 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 06:11:43 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 06:11:43 MediaDownloader syslogd: last message repeated 1 times
Aug 5 06:11:43 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 06:11:43 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 06:16:43 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 06:16:43 MediaDownloader syslogd: last message repeated 1 times
Aug 5 06:16:43 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 06:16:43 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 06:21:43 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 06:21:43 MediaDownloader syslogd: last message repeated 1 times
Aug 5 06:21:43 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 06:21:43 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 06:26:43 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 06:26:43 MediaDownloader syslogd: last message repeated 1 times
Aug 5 06:26:43 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 06:26:43 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 06:32:43 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 06:33:43 MediaDownloader syslogd: last message repeated 1 times
Aug 5 06:33:43 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 06:33:43 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 06:39:43 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 06:40:43 MediaDownloader syslogd: last message repeated 1 times
Aug 5 06:40:43 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 06:40:43 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 06:46:44 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Address family for hostname not supported)
Aug 5 06:47:44 MediaDownloader syslogd: last message repeated 1 times
Aug 5 06:47:44 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 06:47:44 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 06:52:49 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Name does not resolve)
Aug 5 06:52:49 MediaDownloader syslogd: last message repeated 1 times
Aug 5 06:52:49 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 06:52:49 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 06:58:24 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Name does not resolve)
Aug 5 06:58:24 MediaDownloader syslogd: last message repeated 1 times
Aug 5 06:58:24 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 06:58:24 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 07:03:54 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Name does not resolve)
Aug 5 07:03:54 MediaDownloader syslogd: last message repeated 1 times
Aug 5 07:03:54 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 07:03:54 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 07:09:29 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Name does not resolve)
Aug 5 07:09:29 MediaDownloader syslogd: last message repeated 1 times
Aug 5 07:09:29 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 07:09:29 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 07:14:59 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Name does not resolve)
Aug 5 07:14:59 MediaDownloader syslogd: last message repeated 1 times
Aug 5 07:14:59 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 07:14:59 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 07:20:14 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Name does not resolve)
Aug 5 07:20:14 MediaDownloader syslogd: last message repeated 1 times
Aug 5 07:20:14 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 07:20:14 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 07:25:50 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Name does not resolve)
Aug 5 07:25:50 MediaDownloader syslogd: last message repeated 1 times
Aug 5 07:25:50 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 07:25:50 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 07:31:25 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Name does not resolve)
Aug 5 07:31:25 MediaDownloader syslogd: last message repeated 1 times
Aug 5 07:31:25 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 07:31:25 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 07:36:55 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Name does not resolve)
Aug 5 07:36:55 MediaDownloader syslogd: last message repeated 1 times
Aug 5 07:36:55 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 07:36:55 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 07:42:30 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Name does not resolve)
Aug 5 07:42:30 MediaDownloader syslogd: last message repeated 1 times
Aug 5 07:42:30 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 07:42:30 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 07:48:05 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Name does not resolve)
Aug 5 07:48:05 MediaDownloader syslogd: last message repeated 1 times
Aug 5 07:48:05 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 07:48:05 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 07:53:05 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Name does not resolve)
Aug 5 07:53:05 MediaDownloader syslogd: last message repeated 1 times
Aug 5 07:53:05 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 07:53:05 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 07:58:20 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Name does not resolve)
Aug 5 07:58:20 MediaDownloader syslogd: last message repeated 1 times
Aug 5 07:58:20 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 07:58:20 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 08:03:25 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Name does not resolve)
Aug 5 08:03:25 MediaDownloader syslogd: last message repeated 1 times
Aug 5 08:03:25 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 08:03:25 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 08:09:00 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Name does not resolve)
Aug 5 08:09:00 MediaDownloader syslogd: last message repeated 1 times
Aug 5 08:09:00 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 08:09:00 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 08:14:35 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Name does not resolve)
Aug 5 08:14:35 MediaDownloader syslogd: last message repeated 1 times
Aug 5 08:14:35 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 08:14:35 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 08:19:40 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Name does not resolve)
Aug 5 08:19:40 MediaDownloader syslogd: last message repeated 1 times
Aug 5 08:19:40 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 08:19:40 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 08:25:00 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Name does not resolve)
Aug 5 08:25:00 MediaDownloader syslogd: last message repeated 1 times
Aug 5 08:25:00 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 08:25:00 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 08:30:36 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Name does not resolve)
Aug 5 08:30:36 MediaDownloader syslogd: last message repeated 1 times
Aug 5 08:30:36 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 08:30:36 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 08:35:51 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Name does not resolve)
Aug 5 08:35:51 MediaDownloader syslogd: last message repeated 1 times
Aug 5 08:35:51 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 08:35:51 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 08:41:26 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Name does not resolve)
Aug 5 08:41:26 MediaDownloader syslogd: last message repeated 1 times
Aug 5 08:41:26 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 08:41:26 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 08:47:01 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Name does not resolve)
Aug 5 08:47:01 MediaDownloader syslogd: last message repeated 1 times
Aug 5 08:47:01 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 08:47:01 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 08:52:36 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Name does not resolve)
Aug 5 08:52:36 MediaDownloader syslogd: last message repeated 1 times
Aug 5 08:52:36 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 08:52:36 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 08:57:56 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Name does not resolve)
Aug 5 08:57:56 MediaDownloader syslogd: last message repeated 1 times
Aug 5 08:57:56 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 08:57:56 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 09:03:26 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Name does not resolve)
Aug 5 09:03:26 MediaDownloader syslogd: last message repeated 1 times
Aug 5 09:03:26 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 09:03:26 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 09:09:01 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Name does not resolve)
Aug 5 09:09:01 MediaDownloader syslogd: last message repeated 1 times
Aug 5 09:09:01 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 09:09:01 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 09:14:01 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Name does not resolve)
Aug 5 09:14:01 MediaDownloader syslogd: last message repeated 1 times
Aug 5 09:14:01 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 09:14:01 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 09:19:01 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Name does not resolve)
Aug 5 09:19:01 MediaDownloader syslogd: last message repeated 1 times
Aug 5 09:19:01 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 09:19:01 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 09:24:01 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Name does not resolve)
Aug 5 09:24:01 MediaDownloader syslogd: last message repeated 1 times
Aug 5 09:24:01 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 09:24:01 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 09:29:06 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Name does not resolve)
Aug 5 09:29:06 MediaDownloader syslogd: last message repeated 1 times
Aug 5 09:29:06 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 09:29:06 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 09:34:11 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Name does not resolve)
Aug 5 09:34:11 MediaDownloader syslogd: last message repeated 1 times
Aug 5 09:34:11 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 09:34:11 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 09:39:47 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Name does not resolve)
Aug 5 09:39:47 MediaDownloader syslogd: last message repeated 1 times
Aug 5 09:39:47 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 09:39:47 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 09:45:22 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Name does not resolve)
Aug 5 09:45:22 MediaDownloader syslogd: last message repeated 1 times
Aug 5 09:45:22 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 09:45:22 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 09:50:42 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Name does not resolve)
Aug 5 09:50:42 MediaDownloader syslogd: last message repeated 1 times
Aug 5 09:50:42 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 09:50:42 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 09:56:02 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Name does not resolve)
Aug 5 09:56:02 MediaDownloader syslogd: last message repeated 1 times
Aug 5 09:56:02 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 09:56:02 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 10:01:37 MediaDownloader openvpn[2820]: RESOLVE: Cannot resolve host address: hungary.privacy.network:501 (Name does not resolve)
Aug 5 10:01:37 MediaDownloader syslogd: last message repeated 1 times
Aug 5 10:01:37 MediaDownloader openvpn[2820]: Could not determine IPv4/IPv6 protocol
Aug 5 10:01:37 MediaDownloader openvpn[2820]: SIGUSR1[soft,Could not determine IPv4/IPv6 protocol] received, process restarting
Aug 5 10:02:10 MediaDownloader openvpn[2820]: /sbin/ifconfig tun4 10.7.19.20 -alias
Aug 5 10:02:10 MediaDownloader openvpn[2820]: /sbin/ifconfig tun4 destroy
Aug 5 10:02:10 MediaDownloader openvpn[2820]: SIGTERM[hard,init_instance] received, process exiting
Aug 5 10:02:10 MediaDownloader syslogd: exiting on signal 15
Aug 7 22:36:29 MediaDownloader syslogd: kernel boot file is /boot/kernel/kernel
Aug 7 22:36:29 MediaDownloader openvpn[2795]: DEPRECATED OPTION: --cipher set to 'aes-256-cbc' but missing in --data-ciphers (AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305). OpenVPN ignores --cipher for cipher negotiations.
Aug 7 22:36:29 MediaDownloader openvpn[2795]: WARNING: file '/usr/local/etc/openvpn/pass.txt' is group or others accessible
Aug 7 22:36:29 MediaDownloader openvpn[2795]: OpenVPN 2.6.12 amd64-portbld-freebsd13.3 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD]
Aug 7 22:36:29 MediaDownloader openvpn[2795]: library versions: OpenSSL 1.1.1t-freebsd 7 Feb 2023, LZO 2.10
Aug 7 22:36:29 MediaDownloader openvpn[2796]: CRL: loaded 1 CRLs from file -----BEGIN X509 CRL----- REDACTED -----END X509 CRL-----
Aug 7 22:36:29 MediaDownloader openvpn[2796]: TCP/UDP: Preserving recently used remote address: [AF_INET]217.138.192.218:501
Aug 7 22:36:29 MediaDownloader openvpn[2796]: Attempting to establish TCP connection with [AF_INET]217.138.192.218:501
Aug 7 22:36:29 MediaDownloader openvpn[2796]: TCP connection established with [AF_INET]217.138.192.218:501
Aug 7 22:36:29 MediaDownloader openvpn[2796]: TCPv4_CLIENT link local: (not bound)
Aug 7 22:36:29 MediaDownloader openvpn[2796]: TCPv4_CLIENT link remote: [AF_INET]217.138.192.218:501
Aug 7 22:36:29 MediaDownloader openvpn[2796]: WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Aug 7 22:36:30 MediaDownloader openvpn[2796]: [budapest401] Peer Connection Initiated with [AF_INET]217.138.192.218:501
Aug 7 22:36:30 MediaDownloader openvpn[2796]: TUN/TAP device /dev/tun4 opened
Aug 7 22:36:30 MediaDownloader openvpn[2796]: /sbin/ifconfig tun4 10.1.19.30/24 mtu 1500 up
Aug 7 22:36:30 MediaDownloader openvpn[2796]: Initialization Sequence Completed
Aug 13 17:07:07 MediaDownloader openvpn[2796]: [budapest401] Inactivity timeout (--ping-restart), restarting
Aug 13 17:07:07 MediaDownloader openvpn[2796]: SIGUSR1[soft,ping-restart] received, process restarting
Aug 13 17:07:08 MediaDownloader openvpn[2796]: TCP/UDP: Preserving recently used remote address: [AF_INET]217.138.192.218:501
Aug 13 17:07:08 MediaDownloader openvpn[2796]: Attempting to establish TCP connection with [AF_INET]217.138.192.218:501
Aug 13 17:07:08 MediaDownloader openvpn[2796]: TCP connection established with [AF_INET]217.138.192.218:501
Aug 13 17:07:08 MediaDownloader openvpn[2796]: TCPv4_CLIENT link local: (not bound)
Aug 13 17:07:08 MediaDownloader openvpn[2796]: TCPv4_CLIENT link remote: [AF_INET]217.138.192.218:501
Aug 13 17:07:09 MediaDownloader openvpn[2796]: [budapest401] Peer Connection Initiated with [AF_INET]217.138.192.218:501
Aug 13 17:07:09 MediaDownloader openvpn[2796]: Preserving previous TUN/TAP instance: tun4
Aug 13 17:07:09 MediaDownloader openvpn[2796]: Initialization Sequence Completed
Aug 14 21:47:31 MediaDownloader pkg[31735]: libinotify upgraded: 20211018_1 -> 20240724
Aug 14 21:47:34 MediaDownloader pkg[31735]: radarr upgraded: 5.7.0.8882 -> 5.8.3.8933
Aug 14 21:47:34 MediaDownloader pkg[31735]: libimagequant upgraded: 4.3.1_2 -> 4.3.3
Aug 14 21:47:34 MediaDownloader pkg[31735]: bash upgraded: 5.2.26_1 -> 5.2.32
Aug 14 21:47:36 MediaDownloader pkg[31735]: prowlarr upgraded: 1.20.1.4603 -> 1.21.2.4649
Aug 14 21:47:36 MediaDownloader pkg[31735]: liblz4 upgraded: 1.9.4_1,1 -> 1.10.0,1
Aug 14 21:47:37 MediaDownloader pkg[31735]: curl upgraded: 8.8.0 -> 8.9.1
Aug 14 21:47:37 MediaDownloader pkg[31735]: nano upgraded: 8.0 -> 8.1
Aug 14 21:47:37 MediaDownloader pkg[31735]: fontconfig upgraded: 2.15.0_2,1 -> 2.15.0_3,1
Aug 14 21:48:00 MediaDownloader openvpn[2796]: event_wait : Interrupted system call (fd=-1,code=4)
Aug 14 21:48:00 MediaDownloader openvpn[2796]: /sbin/ifconfig tun4 10.1.19.30 -alias
Aug 14 21:48:00 MediaDownloader openvpn[2796]: /sbin/ifconfig tun4 destroy
Aug 14 21:48:00 MediaDownloader openvpn[2796]: SIGTERM[hard,] received, process exiting
Aug 14 21:48:00 MediaDownloader syslogd: exiting on signal 15
Aug 14 21:48:04 MediaDownloader syslogd: kernel boot file is /boot/kernel/kernel
Aug 14 21:48:04 MediaDownloader openvpn[32674]: DEPRECATED OPTION: --cipher set to 'aes-256-cbc' but missing in --data-ciphers (AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305). OpenVPN ignores --cipher for cipher negotiations.
Aug 14 21:48:04 MediaDownloader openvpn[32674]: WARNING: file '/usr/local/etc/openvpn/pass.txt' is group or others accessible
Aug 14 21:48:04 MediaDownloader openvpn[32674]: OpenVPN 2.6.12 amd64-portbld-freebsd13.3 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD]
Aug 14 21:48:04 MediaDownloader openvpn[32674]: library versions: OpenSSL 1.1.1t-freebsd 7 Feb 2023, LZO 2.10
Aug 14 21:48:04 MediaDownloader openvpn[32675]: CRL: loaded 1 CRLs from file -----BEGIN X509 CRL----- REDACTED -----END X509 CRL-----
Aug 14 21:48:04 MediaDownloader openvpn[32675]: TCP/UDP: Preserving recently used remote address: [AF_INET]217.138.192.222:501
Aug 14 21:48:04 MediaDownloader openvpn[32675]: Attempting to establish TCP connection with [AF_INET]217.138.192.222:501
Aug 14 21:48:05 MediaDownloader openvpn[32675]: TCP connection established with [AF_INET]217.138.192.222:501
Aug 14 21:48:05 MediaDownloader openvpn[32675]: TCPv4_CLIENT link local: (not bound)
Aug 14 21:48:05 MediaDownloader openvpn[32675]: TCPv4_CLIENT link remote: [AF_INET]217.138.192.222:501
Aug 14 21:48:05 MediaDownloader openvpn[32675]: WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Aug 14 21:48:06 MediaDownloader openvpn[32675]: [budapest401] Peer Connection Initiated with [AF_INET]217.138.192.222:501
Aug 14 21:48:06 MediaDownloader openvpn[32675]: TUN/TAP device /dev/tun4 opened
Aug 14 21:48:06 MediaDownloader openvpn[32675]: /sbin/ifconfig tun4 10.5.19.12/24 mtu 1500 up
Aug 14 21:48:06 MediaDownloader openvpn[32675]: Initialization Sequence Completed
I’m not 100% sure, but I believe transmission started crashing after updating the following packages (also in the log above): libinotify, radarr, libimagequant, bash, prowlarr, liblz4, curl, nano, fontconfig.
Could anyone provide advice on how to proceed? Is there a more detailed log available?
Thanks for your time,
Matt
TrueNAS Core Version 13.0-U6.2
Jail Version 13.2-RELEASE-p12
