I have Truenas SCALE 24.10 installed on a custom server, with 128 GB of ECC ram, IPMI, two pools, and multiple VMs and datasets.
One of the VMs that I have created on this server is called “Test_Truenas” and is a virtual version of Truenas SCALE 24.10. I now would like to create a mirror pool on two virtual disks (ZVOLS) in the VM, but when I try to do so, I get a warning from Truenas that “There are 2 disks available that have non-unique serial numbers.” Does anyone know how to fix this so that I can create the pool?
Also, I realize that Truenas is supposed to be installed directly on physical hardware, and in nearly all other cases I agree with that, but in this particular case, installing it virtually makes sense, because the purpose is purely testing. Before I upgrade to Truenas 25.04 (Fangtooth) on my physical server (and mess around with manual configuration of instances, formerly VMs), I want to see what Fangtooth looks like, make sure that the pools remain unchanged, and most importantly, make sure that I’m able to roll back to 24.10 if the upgrade causes any problems.
