Unreadable/ uncorrectable sectors after self-test
My TrueNAS just ran into a bunch of problems and I am not quite sure what to do/ how to act or what I should prepare for, and how. Essentially, it reported that /dev/ada2 has 8 offline uncorrectable sectors:
saturn% sudo zpool status -v
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
    #1) Respect the privacy of others.
    #2) Think before you type.
    #3) With great power comes great responsibility.
Password:
  pool: boot-pool
 state: DEGRADED
status: One or more devices could not be opened.  Sufficient replicas exist for
        the pool to continue functioning in a degraded state.
action: Attach the missing device and online it using 'zpool online'.
   see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-2Q
  scan: scrub repaired 0B in 00:00:03 with 0 errors on Thu Mar 27 03:45:03 2025
        boot-pool   DEGRADED     0     0     0
          mirror-0  DEGRADED     0     0     0
            da0p2   UNAVAIL      0     0     0  cannot open
            nvd0p2  ONLINE       0     0     0
errors: No known data errors
  pool: core
 state: ONLINE
  scan: scrub repaired 0B in 03:37:20 with 0 errors on Sat Mar  1 10:37:20 2025
        NAME                                                STATE     READ WRITE CKSUM
        core                                                ONLINE       0     0     0
          raidz2-0                                          ONLINE       0     0     0
            gptid/196085e2-1152-11ea-957b-3cecef012038.eli  ONLINE       0     0     0
            gptid/1a3b1dad-1152-11ea-957b-3cecef012038.eli  ONLINE       0     0     0
            gptid/1b1ee326-1152-11ea-957b-3cecef012038.eli  ONLINE       0     0     0
            gptid/1be79663-1152-11ea-957b-3cecef012038.eli  ONLINE       0     0     0
  pool: jail
 state: ONLINE
  scan: scrub repaired 0B in 00:00:21 with 0 errors on Tue Apr  1 00:00:21 2025
        jail        ONLINE       0     0     0
          nvd0p3    ONLINE       0     0     0
saturn% sudo smartctl -a /dev/ada2
smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p9 amd64] (local build)
Model Family:     Seagate IronWolf
Device Model:     ST4000VN008-2DR166
Serial Number:    ZDH71EQQ
LU WWN Device Id: 5 000c50 0b66abe62
Firmware Version: SC60
User Capacity:    4,000,787,030,016 bytes [4.00 TB]
Rotation Rate:    5980 rpm
Form Factor:      3.5 inches
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Tue Apr  1 10:47:24 2025 CEST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
Self-test execution status:      ( 116) The previous self-test completed having
                                        the read element of the test failed.
data collection:                (  591) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        ( 670) minutes.
Conveyance self-test routine
SCT capabilities:              (0x50bd) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000f   078   064   044    Pre-fail  Always       -       65498192
  3 Spin_Up_Time            0x0003   093   093   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       244
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   090   060   045    Pre-fail  Always       -       1118270736
  9 Power_On_Hours          0x0032   057   057   000    Old_age   Always       -       38112 (166 230 0)
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       143
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   072   057   040    Old_age   Always       -       28 (Min/Max 25/31)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       143
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       582
194 Temperature_Celsius     0x0022   028   043   000    Old_age   Always       -       28 (0 17 0 0 0)
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       8
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       8
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       37351h+40m+06.262s
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       42134266433
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       124152133710
SMART Error Log Version: 1
No Errors Logged
# 1  Extended offline    Completed: read failure       40%     38110         -
# 2  Short offline       Completed without error       00%     38104         -
# 3  Short offline       Completed without error       00%     38080         -
# 4  Short offline       Completed without error       00%     38056         -
# 5  Short offline       Completed without error       00%     38033         -
# 6  Short offline       Completed without error       00%     38009         -
# 7  Short offline       Completed without error       00%     37985         -
# 8  Short offline       Completed without error       00%     37961         -
# 9  Short offline       Completed without error       00%     37937         -
#10  Short offline       Completed without error       00%     37913         -
#11  Short offline       Completed without error       00%     37889         -
#12  Short offline       Completed without error       00%     37865         -
#13  Short offline       Completed without error       00%     37841         -
#14  Short offline       Completed without error       00%     37817         -
#15  Short offline       Completed without error       00%     37793         -
#16  Short offline       Completed without error       00%     37769         -
#17  Short offline       Completed without error       00%     37745         -
#18  Short offline       Completed without error       00%     37721         -
#19  Short offline       Completed without error       00%     37697         -
#20  Short offline       Completed without error       00%     37673         -
#21  Short offline       Completed without error       00%     37649         -
How to interpret all of this?
Thank you for your feedback.
Hi and welcome to the forums.
These are the values you are referring to and that TrueNAS has alerted you for.
These values are generally a good indicator that a drive is failing.
Do you have a spare to replace it? If not then I would suggest you get one ordered.
Your pool is a 4 disk Z2 so nothing major to worry about atm as you can afford to lose two drives before losing data but nevertheless get that disk replaced.
Not to forget:
Replace or RMA as soon as possible.
And one of your mirrored boot drives is unavailable, but this poses no safety risk. Always keep a recent copy of the configuration file at hand.
Thank you both for coming back to me so quickly. I really appreciate the feedback. I guess I need to replace the drive asap.
In that regard: I recently read a lot about manipulated serviced/refurbished Seagate drives which are being sold under false label. I am wondering whether I should shy away from those offers at all and purchase new a new Seagate drive?
Is there maybe any recommendation for reliable yet affordable drives?
Also, if I would want to upgrade storage capacity, I would just swap in the bigger sized one and after replacing the last smaller one, the pool size will be increased automatically, right?
I’m afraid not. Manipulated drives are certainly NOT confined to Seagate, so either you buy new or you have to trust your seller on any ā€œrefurbishedā€ drive (and trust that seller himself was not scammed by its supplier…).
Yes, CORE shall just do the right thing.
Although I hate to say that but, starting with 22 TB drives and a 4-wide raidz2, your easiest path to increase storage is to sidegrade to SCALE and use raidz expansion to go wider. (Of course, if you have a backup, you could just do the old-fashioned backup-destroy-restore, avoid expansion shenanigans, and stay with CORE.)
That makes complete sense. I think I will just look for a good deal on a new drive instead of buying ā€˜something’.
Well, that is another thought I had in the past already, migrate to SCALE. My pool is encrypted which makes moving it fairly difficult. There is a way to remove the encryption via console but I am not sure about this.
Especially because my backup strategy is … let’s say improvable and I am not sure how to do it otherwise. So yeah, ideally I would create a backup and move to scale directly.
Hmm that makes me think: how would I create a backup in the first place? Rsynch from old to new pool? Maybe I could make best use of my current situation, add some extra work and be on SCALE.
