Hi There.
Kinda new to Truenas and VM, but have gotten it all to run, i use the server for NAS and Home assistant through VM. It all ran good for about a month, then after reboot it won’t start the VM for Home Assistant. I rebooted the machine to add a Pcie exspansion card to add more hdd for the nas and now i get this error:
[EFAULT] VM will not start as USB Device: usb_1_1_3 device(s) are not available.
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 198, in call_method
result = await self.middleware.call_with_audit(message[‘method’], serviceobj, methodobj, params, self)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1466, in call_with_audit
result = await self._call(method, serviceobj, methodobj, params, app=app,
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1417, in _call
File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 187, in nf
File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 47, in nf
res = await f(*args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_lifecycle.py”, line 58, in start
await self.middleware.run_in_thread(self._start, vm[‘name’])
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1324, in run_in_thread
return await self.run_in_executor(self.thread_pool_executor, method, *args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1321, in run_in_executor
File “/usr/lib/python3.11/concurrent/futures/thread.py”, line 58, in run
File “/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_supervisor.py”, line 68, in _start
self.vms[vm_name].start(vm_data=self._vm_from_name(vm_name))
File “/usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/supervisor.py”, line 155, in start
raise CallError(
middlewared.service_exception.CallError: [EFAULT] VM will not start as USB Device: usb_1_1_3 device(s) are not available.
I tried removing the exspansioncard and hdd, but this didn’t change anything.
all help much apreciated
