Where to submit bugs in current devel branch ? - problems with 26.04.0-MASTER-20260206 upgrade
When I upgrade from current version: 26.04.0-MASTER-20260206-020156
to 26.04.0-MASTER-20260213-020146 (and same was with 26.04.0-MASTER-20260210-020233)
I am loosing all network configuration - no IP addreses.
(Spend to much time with this stupid Revo AI on Jira with no answer)
You can report bugs via the regular Jira bug tracker and then just set the Affects Versions field for your ticket to Master - TrueNAS Nightlies.
No - I have no rights there as I am not paying customer and can’t find “Submit”. Also Revo told me:
“So: right now, the “Report a Bug” path that throws you into Jira is not a usable route for you as a nightly / experimental user.
The Jira is the Community Edition bug tracker. Enterprise customers have a separate support portal.
Atlassian’s chat bot was clearly just making an assumption there, but there’s no reason as a Community or nightly user you should be prevented from filing a bug ticket. There should be a Create + button in the top toolbar on Jira that allows you to file a report.
Thanx for help! Now it seems that I can submit PR.
